Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
PT Radio problem
Like Tree5Likes
  • 2 Post By rckstein
  • 2 Post By Fk5
  • 1 Post By rckstein
Old 08 Mar 2012, 08:46 am
Unhappy PT Radio problem
Hello everyone,
I'm new to the site but would appreciate some help.
I had some work done on the ignition (lock jammed so moved to a supplementary switch). Radio stopped working. Bought a used radio, all connections made and checked but no display to enable me to put CODE in (tried 3 radios - same result). If I remove the tiny plug-in (top right corner as seen from radio back - 1 wire and loose connection of plug to wire), the radio lights up with CODE. Put in (correct)code but not accepted (says REPEAT then after 3 goes WAIT - for half-hour)
Anyone know what that little connector is for?
Also, CODE comes up when the on/off switch is in the OFF position, not ON - seems odd.
Old 08 Mar 2012, 01:00 pm
Default Re: PT Radio problem
DUPLICATE POST!
Old 14 Jul 2017, 10:47 am
Originally Posted by popeye View Post
Hello everyone,
the little connector beside the big main one i believe is for a cd changer it dont need to be plugged in for the radio to work.
on the big plug check for voltage on the 2 purple wires , with ignition turned off, should have battery voltage
then check that you have voltage to the red wire with a white tracer this one should have power with ignition turned on,
Old 14 Jul 2017, 10:59 am
rckstein's Avatar
You responded to a 5+ year old thread, and while your advice may help someone in the future, the OP to this thread hasn't been back on the forum since 03/12
Old 14 Jul 2017, 11:34 am
Fk5 Fk5 is offline
I still appreciate the answer. It helps when using the search not having to bounce from thread to thread to find the one with the answer
2003 GT 5 speed
162,000 miles
Old 14 Jul 2017, 01:02 pm
rckstein's Avatar
That's why I said it may help someone in the future, nothing wrong with that, just like no question is a stupid question
grandads_shed likes this.
radio problem bobs turbo pt Sound and Security Forum 4 09 Nov 2011 11:20 am
a little problem with my radio CruseadorPT Sound and Security Forum 1 06 Aug 2009 05:12 pm
RADIO PROBLEM>>> mjb457 Interior Accessories Forum 5 10 Feb 2009 06:15 pm
Radio Problem aldo Sound and Security Forum 1 01 Nov 2008 06:29 pm
03 radio problem momnapt Sound and Security Forum 3 14 Nov 2007 03:05 pm
