Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Cruise control problem
Old 09 Aug 2012, 09:18 am
Smile Cruise control problem
Hi and good morning.
My cruise has started to give me a little grief.
Sometimes when I turn on, it turns itself off after about 2 seconds.
Other times it stays on and works for a while, then turns off.
On both occasions, it will not turn back on until the key has been taken out and car restarted.
Thanks in anticipation guys, Kev
Old 12 Aug 2012, 10:00 am
2step's Avatar
Default Re: Cruise control problem
That's an unusual problem that I have never heard of before this. Is anything else acting up in any way at all? Sometimes a low battery can cause strange little electronic gremlins to show up. Almost everything is controled by the PCM on these cars so I hope it's not a problem there. You could try disconnecting the battery and drianing the power reserve by keeping the door/dome light on and holding the brake pedal down to trip the brake lights. This causes a "poorman's" reset of the PCM and sometimes fixes little hic-ups in the electronics. At least it's free to try and the only down side is you will have to reprogram your radio stations and clock.
Good luck and keep Cruisin'
Old 13 Aug 2012, 02:25 am
Thanks for that. Will give it a try and let you know.
Kev
Old 13 Aug 2012, 09:19 am
check the vacuum line coming from the brake booster to the CC canister for a leak?
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 13 Aug 2012, 10:25 am
Thanks for that, but could you point me in the right direction.
Cheers
Kev
Old 21 Aug 2012, 06:55 am
I have now bought a donor car with working cruise. Could someone tell me exactly which bits to change over. Thanks.
I did disconnect the battery for a couple of hours, but no difference
Cheers
Old 21 Aug 2012, 05:17 pm
You can learn a lot with your donor car. You may as well replace everything short of the wiring harnesses.
Replace the cruise vacuum actuator and the control cable to the throttle.
Under the right front fender well is a black plastic box, the vacuum reservoir. Replace it.
Replace all of the vacuum tubing and fittings.
Inside the car, remove the steering wheel--CAUTION, airbag alert. This is at your risk. Replace the cruise controls stalk.
Check all connectors between the actuator connector and the multifunction and cruise switches. Repair or replace any bad wiring, connectors.
This may or may not also include wiring and switches for brake, (clutch), transmission, throttle position sensor, speed sensor, MAP, fuse boxes.
What else? Computer? Wiring harness?
Cheers
Old 22 Aug 2012, 05:33 pm
2step's Avatar
This is do-able but there are a LOT of details and parts to switch over, under the hood and at the steering wheel. A repair manual would be a minimum requirement, at least for me.
cruise control problem Wonderjava Tech & Performance Forum 2 17 Jun 2012 02:16 pm
PT Cruise Control problem alhebb General PT Cruiser Discussions 3 13 Jul 2011 02:00 pm
Cruise Control blown05gt Tech & Performance Forum 0 17 Apr 2011 09:42 pm
Cruise Control problem puuha General PT Cruiser Discussions 6 21 Dec 2010 10:22 am
Cruise Control Problem meandean General PT Cruiser Discussions 12 26 Mar 2010 03:29 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
