Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Engine coolant replacement
Old 14 Dec 2012, 04:14 pm
Default Engine coolant replacement
My wife's car needs a coolant replacement and I want to do it myself. Do you know if there is somewhere in the circuit a valve that drains the coolant? Not too easy to check underneath...
Thanks
Old 19 Dec 2012, 10:46 am
swanjack's Avatar
Default Re: Engine coolant replacement
Yes, there's a valve at the bottom of the radiator, driver's side iirc, facing backwards,just above a drainage tube. Turn it 90 degrees to open the flow I think, although I just took off the bottom hose.
Old 19 Dec 2012, 06:37 pm
I believe that you need to turn it 90 degrees and pull it out toward you. I've always found that you are quicker (and just as messy) to pull off the bottom hose. It drains much faster.
Old 20 Dec 2012, 01:51 pm
Just to clarify things, you mean that the valve is at the right bottom side of the radiator, as you see it from the front of the car?
In other words, driver's side as we use it at over Europe, except UK?
Old 20 Dec 2012, 03:46 pm
If you stand at the front of the car looking toward the windshield, the drain is on the right hand side at the bottom of the radiator facing into the engine compartment. It's not easy to see from above but is obvious if you are under the car.
There are pictures of it on this site, try searching for radiator drain plug
Old 20 Dec 2012, 03:58 pm
Here's a drawing of it from the POV of being under the car
Old 20 Dec 2012, 04:44 pm
Thanks !
Tags
antifreeze, coolant, replacement
2001 PT - Engine mount replacement needed with Oil pan replacement? SanPT Tech & Performance Forum 14 23 Sep 2012 08:49 pm
Engine coolant leak help Vicky Tech & Performance Forum 9 25 Jul 2012 04:22 pm
Special engine coolant fluid mstyler05 Tech & Performance Forum 8 19 Jun 2010 12:12 pm
Faulty Engine Coolant Sensor? thegoldpt Tech & Performance Forum 6 17 Jun 2010 08:14 pm
engine coolant reservoir empty? PTC06Peet General PT Cruiser Discussions 19 17 Jun 2010 07:58 pm
