Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Issues with filling up my CRD (UK)
Old 29 Dec 2012, 04:18 am
Default Issues with filling up my CRD (UK)
Hello,
i have recently bought a '05 cruiser limited 2.2 crd and just been to fill it up for the first time and the diesel nozzle doesn't fit into the filler pipe very well? when you put it in as far as it will go it clicks off every 2 seconds like the tank is full. I had to hold the nozzle out of the pipe and point it at pipe to get it to fill. I was definately using the car one, it was as if i was trying to fill a petrol car with diesel nozzle.
Is this normal?
Old 30 Dec 2012, 10:51 am
Default Re: Issues with filling up my CRD (UK)
Hi i had the same problem's 5 year's ago when i got my CRD, the nozzle only goes so far but you start off filling up slowly then increase the flow.The pump cut's out due to an air lock or blow back at the nozzle this is normal.
Old 31 Dec 2012, 08:10 am
At least its kinda meant to be like that
Old 31 Dec 2012, 01:16 pm
I had a neon that did the same thing, turns out at some point the filler neck itself was replaced, and the tubing used was a smaller diameter than the original, which caused a vaccume blow back.
Just gotta fill her slow. Fine in the summer, cold to do in the winter :-)
Old 31 Dec 2012, 02:20 pm
Its really really slow to fill, unless i hold the nozzle and point it down the hole, it works fine then but usually ends up with diesel on the floor once the tank fills.
I had a look and i think i may have the same problem the mother in laws voyager had where the metal cap falls off the filler cap and goes down the pipe restricting flow. Might get my flexi bit of wire and have a poke around.
Old 09 Mar 2013, 10:12 am
DieselPunk's Avatar
I've experienced the same thing at certain filling stations - usually I just pull the handle out just a tad. Must have something to do with air backing up the nozzle while the diesel is flooding in!
2002 2.2 CRD Limited Diesel Panelvan Conversion "Love and Thunder"
Need some help with a few issues! dcsocal General PT Cruiser Discussions 11 13 Apr 2011 07:59 pm
Hard Starting after filling Feul tank easydude51 Tech & Performance Forum 4 31 Jan 2011 11:23 pm
A/C issues... usmcwifey Tech & Performance Forum 8 07 Apr 2010 07:36 am
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
Filling up that tire wall tricky 4 me =[ Joeskey Wheels, Tires, Suspension 2 29 Dec 2007 01:19 pm
