Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
air intake sensor crd ......uk
Old 08 Jan 2013, 04:25 pm
Default air intake sensor crd ......uk
hi guys
i need to replace an air intake sensor on our 2.2 crd but have not got a clue where it is on the engine , anybody know????
cheers
mark
Old 08 Jan 2013, 05:54 pm
Default Re: air intake sensor crd ......uk
Should be plugged right into the rubber hose coming off the intake :-)
Old 09 Jan 2013, 03:55 pm
thanks buddy ,is it easy to replace ??
mark
Old 22 Jan 2013, 03:32 pm
Before you replace it, try to clean it.
NOT WITH ANY TOOL, OR YOUR HANDS.
Get a carb cleaner spray, remove the rubber hose that comes from the air filter, unplug carefully the cables from the censor's plug and spray the censor inside the tube.
Do it 2 - 3 times and re install everything as they were.
Maybe you will save a couple of bucks...
CrankShaft Sensor/CamShaft Sensor Questions PTMomma Tech & Performance Forum 8 12 Aug 2014 01:43 pm
Intake air temperature sensor Badglas Tech & Performance Forum 17 31 Aug 2012 10:36 am
crankshaft position sensor veses knock sensor BeagleDad Tech & Performance Forum 6 13 Feb 2012 06:10 pm
air intake sensor slinger General PT Cruiser Discussions 10 21 Jun 2011 07:13 pm
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
