Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Instant loss of power
Like Tree3Likes
Old 07 Mar 2013, 03:07 pm
Default Instant loss of power
Maybe you have felt it, maybe not.
There are times when shifting down to 2nd gear, (suppose I am getting into a turn), I KNOW that I have the right gear, but the car, although it has 1300 - 1400 RPM, for a split of a second, makes this kick, loosing the power and gains it up again.
It is almost the same symptom as if I hadn't chosen the right gear, but a higher one.
But the RPMs are right. Second gear should rev up without hesitation. And it does after all. Right after this kick the car accelerates normally.
This happens in both gas and petrol, so it has nothing to do with jet nozzles.
Spark plugs are almost new (replaced 6000 km ago)
Any suggestions, where to start looking?
Old 27 Jun 2013, 12:20 pm
Default Re: Instant loss of power
Just yesterday a technician told me that this instant loss of power, (just for a split of a second), is the result of timeworn ignition (spark plug) cables, and maybe an already broken spark plug.
What is your opinion on this?
I already started a separate thread to find the part numbers for these cables.
I remind that my wife owns a 1,6 2005 model.
Old 07 Jul 2013, 01:36 pm
For anyone interested in the above, just an update.
That instant loss of power was due to worn ignition cable, which in turn, made spark on the porcelain body of the spark plug No 3. With the continuous sarks the porcelain overheated and cracked, resulting to a misfire of the particular No 3.
Changing the ignition cables and the worn spark plug, eliminated the problem.
If this ever happens to you, look at the inner side of the rubber cable, which comes in contact with the porcelain. You will notice some white lines on the rubber. These indicate that there were sparks from that point.
Old 07 Jul 2013, 02:04 pm
randyincctx's Avatar
Thumbs up Re: Instant loss of power
If they were the original stock cables....They are 5h1t,and needed to be changed a long time ago......
Aka:~KILLER~
Old 07 Jul 2013, 03:00 pm
I wonder why people say this. I have seen a few with 100k and still no issue. now I don't recommend that interval, but that's not bad If you think about it.
Old 07 Jul 2013, 03:04 pm
The posts that preceded did not say you had a miss. Only loosing power. So when I read this the first time I had no idea to offer. A communication issue I guess. Glad you got it resolved. Thank's for letting us know how things turned out.
Old 07 Jul 2013, 03:21 pm
Wink Re: Instant loss of power
Think about it....The plug/ignition wires were purchased & installed by a MFG that eliminated a passenger side door lock cylinder to save $2......I can't imagine they spent very much on plug wires.
Aka:~KILLER~
Old 07 Jul 2013, 03:52 pm
Then why would we buy the PT to begin with. Because that logic dictates that the whole thing would be that way. Motor parts, trans parts, brakes, and any thing else. I personally would prefer some proven fact not this type of fiction. Certainly not the kind of evidence to use in parts recommendations to others. Because some of the old post say this doesn't make it fact.
randyincctx likes this.
Old 07 Jul 2013, 07:05 pm
That IS very true.....
Aka:~KILLER~
Old 21 Nov 2014, 01:45 pm
By "miss" you mean "misfire"? Sorry, English is not my native language, so I am not aware of all the correct technical terms to use.
Power loss in '06 GT Joven76 Turbo Performance 12 30 Aug 2011 05:42 pm
Power and MPG Loss Smurfy Tech & Performance Forum 10 28 Jun 2011 08:31 am
Power loss littleblueGT Turbo Performance 3 11 Apr 2006 11:45 pm
Power loss? turbomangt General Turbo Discussions 9 28 Jul 2005 12:55 am
Power loss Betsey General Turbo Discussions 5 10 Dec 2003 03:45 am
