Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Under seat battery removal diesel
Old 13 Mar 2013, 11:37 am
Default Under seat battery removal diesel
I have to replace my under seat battery on my 2.2 CRD, can I assume it is quite easy or are there any tricky issues?
Thanks
Old 04 May 2013, 03:43 am
DieselPunk's Avatar
Default Re: Under seat battery removal diesel
It's fiddly and space is tight making it awkward. If you do need to replace it it appears as if it's only the Optima battery that fits. I tried another sealed gel based one (cos it lays on its side you can't use lead acid) with a bull on it but despite having the correct dimensions didn't fit. The battery needs a flat top with the terminals extruding in order to route the cables in that cramped space.
2002 2.2 CRD Limited Diesel Panelvan Conversion "Love and Thunder"
Old 14 Aug 2013, 03:07 pm
Really easy, just slides forward after you remove the two plastic cover screws, the bottom bolt (on the front) and the power wires.
Seat Belt warnings etc. removal from sun visors RIGBY PT Cruiser Convertible Forum 3 15 Nov 2012 05:42 pm
Front seat removal Hvymtl General PT Cruiser Discussions 0 07 Sep 2011 01:35 pm
Front Seat Plastic Side Panel Removal NightWing General PT Cruiser Discussions 6 11 Jun 2010 07:56 pm
Front Seat Side Panel Removal NightWing Interior Accessories Forum 0 09 Jun 2010 04:06 pm
Rear seat removal in a convertible? Dozer42 PT Cruiser Convertible Forum 4 21 Jan 2008 10:47 am
