Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Start problems 2.2 CRD 122hp - Battery replacement doesn't seem to have effect
Old 04 Apr 2013, 04:25 am
Default Start problems 2.2 CRD 122hp - Battery replacement doesn't seem to have effect
So.. here we are..
I currently have some issues with a PT Cruiser '04 2.2 CRD
  • It didn't want to start good
  • Then it didnt start at all
  • When we give it a pull and put in gear runs fine
  • Changed battery from my own car
  • Started fine
  • Bought new battery, same specs as mine (72ah / 680a cold start)
  • Doesn't want to start again
  • Linked another battery to the new one with cables
  • Still doesnt want to start.....
  • Gave it a pull again, runs fine...
Now.. we were pretty sure that the battery was the problem.. untill now !?
Anyone got any clues ? Could it be the starter that doesn't go around fast enough or...?
One thing that might be of value is that the 4th injector at the end of the rail shows a very small leak. This was however the case for a few months already and this wasn't a problem when starting with my battery ?
I really don't have a clue what could be the problem right now ?
Any advice much appreciated !
PoloB12
Old 04 Apr 2013, 06:23 am
ROCKETMAN8060's Avatar
Default Re: Start problems 2.2 CRD 122hp - Battery replacement doesn't seem to have effect
Did you check the coil?
ROCKETMAN8060
Old 04 Apr 2013, 06:45 am
Thank you for your response, but could you explicate a little more ?
I don't understand what u mean... Language issue as well since I am Dutch.
Thanks
( BTW ITS A DIESEL, SHOULD THE COIL REFER TO IGNITION COIL )
Old 04 Apr 2013, 11:23 am
Crid's Avatar
Thanks
Yes check the ignition coil.
2006 Cruiser, Non-Turbo, 19 inch Konig Trouble rims on 225/35/19 Ironman Imove tires, Airaid CAI, E3 Plugs, msd super conductor 8.5 mm wires, Freedon Design Strut Tower Brace, Glow Shift Pillar gauges, EBC Slotted Rotors with EBC Green Stuff Ceramic Fiber Core Pads, Lowerd on Tien springs, Full Custom Kenwood Excelon sound system with 1 12" JL Audio W0, 8000k Blue hids up top and aftermarket OEM Fogs with white 8000k in bumper. Ipcw Bermuda black true led taillights with tinted reverse lights.
Old 04 Apr 2013, 11:29 am
Sorry guys, but a diesel engine doesn't have an ignition coil as far as I know ?
We did change the glow plugs if that's what you are referring to ?
Thanks
Old 04 Apr 2013, 11:34 am
Crid's Avatar
Thanks
No I did mean the coil didnt realize it was deisel. Hmm I'm stumped may have to wait for some one else to chime in good luck tho. Lots or smart ppl on here
Old 04 Apr 2013, 11:43 am
Just realised now that I am on an American forum where diesel engines are not common at all, maybe not even sold at all..
Someone has been so kind to move this topic to the correct section on this forum.
Thanks
Old 04 Apr 2013, 12:07 pm
cruserdad1976's Avatar
you r right no desiel PT s here there were a small number of the Jeep Libertys sold with the desiel but no pts i am told we can not even import them
Old 04 Apr 2013, 04:02 pm
To summarize, seems it starts with getting wheels turning and putting in gear, but not with starter....
If I have that right, check the cables going to the sarter - it isn't your starter itself, since it turns, but I suspect you have high resistance due to corrosion.
Old 05 Apr 2013, 06:18 am
Thanks for your reply, is there some easy way to check the resistance of the starter ?
How would you explain the fact that with the battery from my car it does start ? And an brand new with same specs does not work ?
Thanks
BATTERY REPLACEMENT? WAGGGG General PT Cruiser Discussions 1 04 Jul 2012 02:44 pm
2003 Touring doesn't start TimothyG Tech & Performance Forum 3 11 Jan 2011 07:36 am
2001 PT Cruiser Doesn't Start Properly cusunfireguy Tech & Performance Forum 5 22 Jun 2010 05:39 pm
