Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Stif gear shift
  • 1 Post By CREWZIN
Old 29 Jun 2013, 02:41 pm
Default Stif gear shift
Just recently I noticed that the gear shift is not so smooth as it was. In fact there are times that I must press the clutch pedal with all my strength, all way down, and still the gears are not shifting smoothly as they should.
From my knowledge I understand that the clutch disk is worn and needs to be replaced soon.
For the moment, do you guys know if there is some kind of regulator nut, so I can temporary make the shifting a little smoother?
Old 29 Jun 2013, 03:56 pm
Default Re: Stif gear shift
Don't have a stick shift but fro what I've been reading on the forum, it's the bushings on the shifter linkage that's your problem. Many have replaced the bushings with bugger bushings (don't laugh, that's the real name) and the shifting problems disappear. Here's some older posts on the subject:
How to Install Booger Bushings?
PT shifter bushings replacement
2002 PT Cruiser Shifter Wont Go Into Reverse - Manual 5 speed - Fixya
UptownSport likes this.
Old 29 Jun 2013, 04:32 pm
UptownSport's Avatar
^^^ yep, definitely get boogers, and check clutch adjustment.
Stiff transmission when hot?
Old 01 Jul 2013, 12:28 am
That's the question. How can I check the clutch adjustment?
Old 01 Jul 2013, 09:31 am
Old 02 Jul 2013, 11:49 am
Thanks Uptownsport
I 'm going to try it A.S.A.P.
Old 02 Jul 2013, 12:38 pm
AND DID IT!
Thanks again.
Won't shift out of first gear Cybergarage Tech & Performance Forum 13 06 Jan 2016 04:13 pm
Very hard to shift into first and second gear Sloanr333 General PT Cruiser Discussions 6 30 Apr 2012 11:18 pm
Gear shift change out Purevil Interior Accessories Forum 9 28 Mar 2011 05:54 pm
WTA: My Automatic Transmision Only 1&2 Gear Can't Shift? Flx_18 Tech & Performance Forum 5 19 Feb 2011 05:08 pm
Auto Tranny will shift even if in 1st gear? BumperBob Tech & Performance Forum 4 07 Apr 2005 11:07 am
