Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
code p0340
Old 27 Jan 2014, 05:45 pm
Default code p0340
I have codes p0551 and now p0340 coming up. The engine was over heating and I fillled Up twice with coolant then it was jerky if the revs above 2000 and lost power. Now today its driving nicely but the water temperature won't rise at all and the heaters not working.
I also have a sqeak from the fan belt intermittently.
Does anyone have any thoughts on this?
2002 Touring Pt Cruiser. Petrol Automatic. 87k miles
Old 27 Jan 2014, 06:22 pm
Default Re: code p0340
Thoughts?
P0551 - you should replace the Power Steering pressure switch.
P0340 - You should replace the Camshaft sensor, but only with one from the dealer.
Re-filling the coolant twice - find where it's leaking either externally or internally. No heater maybe because the heater core is the highest level and your low in coolant. When you re-filled the system, did you bleed all the air out?
Old 27 Jan 2014, 06:31 pm
Hi thanks, I will order new sensors.
No I didn't bleed the air as I was by the roadside so just filled up the coolant.
Code P0340 ?????? jondickson Tech & Performance Forum 23 15 Aug 2013 08:48 pm
02 pt with p0340 code webstertroy General PT Cruiser Discussions 11 19 Jan 2013 09:26 pm
P0340 Code DragonBuddha06 Tech & Performance Forum 3 13 Sep 2011 09:06 pm
Code p0340 tommyis3 General Turbo Discussions 3 16 May 2009 01:51 pm
code p0340 sflamedic General PT Cruiser Discussions 5 21 Oct 2008 06:12 am
