Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Anyone changed a 2.2 diesel alternator?
Like Tree4Likes
  • 1 Post By rsmotorworks
  • 1 Post By chuzz
  • 2 Post By surfy
Old 01 Jul 2014, 03:49 pm
Tobymelodeon's Avatar
Default Anyone changed a 2.2 diesel alternator?
My alternator has started screeching and making a horrible metallic grinding noise. After disconnecting the auxcillary belt and isolating the alternator it would appear hat the clutch mechanism in it is shot to bits... So need to replace.
Being a euro 2.2 crd, not much around to tell you the process however after some research, it appears that you gave to basically strip the front end of the car including both water and ac radiators (which would mean needing a complete regas for the ac system!) and removing the front main cross member, just to be able to get to the bolts! Seems a bit extreme!
Has anyone done one if these? Can the radiators be leaned forward enough to get the alternator out without. Having the completely disconnect them.?
Any past experiences greatly welcome, although I realise the majority of you are US based petrol owners.
Thanks off your help,
Toby
2002 PT Cruiser CRD in Bright Silver.
Current Upgrades
Chrome door handle cups, chrome pillar covers, tinted windows, custom vinyl flame decals, alloy wheel decals, Enrgy bush kit, Engine cover MOD, LED Side Repeaters
17" Ace Manta Alloys, Red Brake callipers, Front grille MOD
Project list (wish list)
Rear bumper mod to DIY roll pan
Custom paint job (probably purple front end with flames running into the silver)
Air intake upgrade...
Old 01 Jul 2014, 05:10 pm
cruserdad1976's Avatar
Default Re: Anyone changed a 2.2 diesel alternator?
well as much as Il like to say SURE IVE tone a bunch of them most of us on this forum have never even seen a 2.2 let alone work on one we have learned that the battery is under the seat and it is expensive and that running them till the E light pops on is BAD BAD BAD but other than that soory not much help
Old 03 Jul 2014, 02:38 pm
Toby
Hello,
I currently have 2.2 diesel in the UK which has the same problem. I took the alternator off and the pulley fell into pieces.
To remove the alternator the slam panel was removed, along with the radiator (the previous owner had removed the aircon rad for some reason so I thought I'd take the rad off as someone had sprayed it blue ?). Take the top left engine mount (putting a jack underneath the left side of the engine) and jack up the engine in order to remove the bolts.
Not a very difficult job. I specialise in PT Cruisers in the UK so send me an email if you get stuck, info@rsmotorworks.co.uk
Handy_Cruiser likes this.
You can do it by removing the slam panel.
The rads can be pulled forward and held.
But you will need to remove the inlet manifold
Don't forget to order new seals and you may as we'll replace the short turbo hose as it needs to come off,
That's how I done the last one.
Old 03 Jul 2014, 02:45 pm
Toby
Each to their own but I have done it with the manifold on, turbo hose on.
Old 04 Jul 2014, 04:24 pm
Half way through...
Managed to get the old one out, leaving the rads in place but removing the manifold. Didn't want have to pay out for regas so improvised. Nightmare to get to certain bolts. Have photographed the process so will make a how to post once finished, just in case someone else needs the help
Air manifold was full of muck so needed removing anyway.
Current Upgrades
Old 21 Sep 2016, 04:05 pm
Lankytim's Avatar
Did this get sorted? My 2.2 diesel had a noisy alternator and now the battery light has come on. There's almost no info out there on this model!
Old 22 Sep 2016, 08:36 am
Lankytim, I'd suggest sending rsmotorworks a pm. He seems to be willing to help and it sounds like his method works. We're not familiar with the CRD over here in the States as the bastards here never offered it to us. I'd love to have one, just to learn about diesel engines.
uncomn likes this.
Old 15 Nov 2016, 02:15 pm
leave rads in and take out headlight.ac hoses are a pain as are torx heads on bolts.
Old 15 Nov 2016, 02:19 pm
noisy alternator .it would be easier to change pulley in situ with the headlight removed.will need a 17mm star torx for pulley.
Handy_Cruiser and Sinbad like this.
WhatElseShould Be Changed When Timing Belt Is Changed? myjeephatesme Tech & Performance Forum 5 02 Jun 2014 01:51 pm
PT Cruiser Diesel! tuka General PT Cruiser Discussions 18 01 Dec 2011 03:01 pm
2.2 diesel baz General PT Cruiser Discussions 2 29 Oct 2011 10:05 am
Not a diesel, but it's sounding like one... Mazarin General PT Cruiser Discussions 4 10 Aug 2011 11:14 am
2.2 CRD Diesel Conversion JaxCruzzer General PT Cruiser Discussions 4 02 Feb 2011 05:57 pm
