Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
2.2 Crd cruiser
Old 17 Aug 2014, 12:38 pm
Default 2.2 Crd cruiser
Hi, Ok update, as I don't seem to being getting anywhere and I
am still have trouble getting this car to charge. Don't forget I'm in the UK. So I think maybe these colour coded diagrams could be wrong as they do not show up in my wiring loom. The other thing was when I purchased the alternator the guy told me some have 3 wires and some have two. I am truly stumped from your diagram I seem to have a wire missing, but I cant find it any where. Could you please advice. The wires I have are Black from starter motor continual live, and light blue. There is juice coming down to the black wire 12.59V. When I disconnect the blue wire and switch on ignition I have 8 volts coming from it. Immediately on start up attached or disconnected it drops to 0.09Volts.I don't have the specs on the car so I don't know what voltage should be coming down this blue wire, if any. Any advice would be truly appreciated.
Thanks
Kevin
Old 17 Aug 2014, 02:43 pm
Default Re: 2.2 Crd cruiser
Originally Posted by scorpionking View Post
...when I purchased the alternator the guy told me some have 3 wires and some have two. ...
Thanks
Kevin
I cannot help with diagnostics, only schematics.
Three wires from generator (see below):
"A" goes to the starter motor and has an inline fusible link.
"B" goes to the PDC auto-shutdown relay.
LB/Wt wire runs from alternator to the PCM.
Note in the diagram, the computer wants info from the battery temperature sensor.
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
