Not in the UK but in The Netherlands!
Try here |
![]() Quote:
PT Cruiser Maintenance Parts and Spares, belts etc |
Sorry ive been working away ..
Rod that's excellent thank you I'll give them a try...... Regarding the shifter bush, I've bought and replaced the bush with a new 1 and it's not much better ?! It's still hard to get into 1st so is the other bushes underneath ?
Nuclear Sector sorting out the electrons, neutrons and croutons Last edited by ProperTricky; 07 Nov 2014 at 11:37 am. |
![]() Quote:
The Puddle O'Meter is off the scale today so I'll have a look tomorrow ..
It seems more difficult to select a gear when warm, would that make sense ?
Nuclear Sector sorting out the electrons, neutrons and croutons Last edited by ProperTricky; 08 Nov 2014 at 06:34 am. |
I am not so sure if I am answering for the correct part, but if you refer to the rubber bushings that lock on the lever over the transmission box, at the end of the 2 cables, then maybe I have a solution to that.
Just replaced mine with a piece of plastic cut on a lathe to take the right shape. Over the big plastic ring that surrounds it, I put a washer to keep all in place. Made a small hole on the pin and used a safety lock to keep the washer in place I can post a picture tomorrow if you want. |
Hi,
Yes it's the bush on the end of the gear lever cable above the gearbox, i replace with a plastic upgrade from the States and although it's a little better i wouldnt say it's perfect as it's still hard to get into some gears. The car has only done 80,000 and the biting point of the clutch is still very low so a failing clutch can be ruled out, My next job is to check the gearbox oil but i just havent had the time yet ... Appreciate the reply thank you.
Nuclear Sector sorting out the electrons, neutrons and croutons |
Thread Tools | |
Display Modes | |
Gearbox clunking | stek2008 | General PT Cruiser Discussions | 4 | 07 Oct 2013 08:35 pm |
clutch cable or shifter cable? is AAMCO Loco? | prowlerclone | PT Cruiser Convertible Forum | 16 | 03 Sep 2012 05:36 am |
Gearbox replacement | swordfish | Tech & Performance Forum | 2 | 14 Oct 2010 07:22 pm |
Gearbox noise?? | siscor | Tech & Performance Forum | 6 | 03 Sep 2010 02:24 am |
gearbox faults | kenjenkins0123 | Tech & Performance Forum | 3 | 22 Mar 2009 08:21 am |
