Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
2.2 CRD 2002 electric problem
  • 1 Post By Croiser
Old 31 Dec 2014, 10:30 am
Croiser's Avatar
Default 2.2 CRD 2002 electric problem
Hi, everybody!
Finally my 2002 2.2 CRD has arrived, but there is a problem with electrics, I suppose.
When turn the key once (giving contact) everything works fine (wipers, heating fan, windows going up and down, turn signal, etc.) but when I start the engine, everything stops working...
Fuses are ok, only the fog fuse is broken.
Happy new year to all of you!
Old 31 Dec 2014, 11:42 am
Default Re: 2.2 CRD 2002 electric problem
Welcome to the cruiser world. Greetings from NW Pacific USA.
When the ignition switch is rotated to start, many of the cars electrical functions are temporarily disconnected. I assume this is to reserve the power for the starting system.
As long as everything works when the car is running, all is OK.
If systems are totally failed, you may need an ignition switch.
Old 31 Dec 2014, 11:55 am
Croiser's Avatar
My problem is quite opposite; when I start the engine, some things stop functioning (wipers, windows, etc.).
Old 31 Dec 2014, 02:12 pm
Still likely to be ignition switch, as they go bad fairly often.
Does radio display go off? That is common with bad switches.
Try pushing in on the key and see if that helps.
Old 01 Jan 2015, 02:39 pm
Croiser's Avatar
I've tried that, but it didn't help. Also, when I turn the lights on while engine is running, the mileage digital numbers become almost invisible.
Old 01 Jan 2015, 04:14 pm
Croiser's Avatar
You were right!
I've tried to push the key again and it solved the problem.
While the engine was running, I've moved the key for about one millimeter to the left and everything worked just fine.
Thank you!
Old 02 Jan 2015, 12:51 pm
Originally Posted by Croiser View Post
You were right!
Thank you!
That's great, but it indicates the switch is on its way out. There are threads on here of people who've replaced theirs - not too expensive/difficult.
Old 05 Jan 2015, 09:32 am
Croiser's Avatar
I was wondering, would it be smart to replace it with the ignition push start button switch?
Old 05 Jan 2015, 11:18 am
Not sure - you'd still need key to turn to "ON", just use button for "START", right? Not sure that would help.
Look at how long original switch lasted - key rings with lots of keys on them seem to shorten the life of the switches.
2002 overheating problem christy11_2 General PT Cruiser Discussions 10 14 May 2014 09:26 am
2002, CV problem StrayCatalyst Wheels, Tires, Suspension 33 19 Jun 2013 04:04 pm
left electric window on 2002 ptc limited edition not working stanley General PT Cruiser Discussions 1 22 Jan 2013 07:45 am
auto-door lock or electric problem? jsampson General PT Cruiser Discussions 5 04 Feb 2009 06:40 am
