Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Couple of issues...
Old 13 Jun 2015, 08:20 am
Default Couple of issues...
I bought my first PT Cruiser (2001 Limited Edition, 135000 miles) last week for 200, I had to spend another 200 on getting a new Power Steering Pipe installed as the original was leaking... now I have a weird, loud, squealing noise from the engine when I drive.
Also the car only came with one key and no remote, when I use the key in the drivers door it only opens the drivers lock, it makes the sound like it's trying the other locks, but nothing happens, any ideas what this could be?
The lock button on the drivers door still works and locks/unlocks all the doors.
Old 13 Jun 2015, 09:00 am
Default Re: Couple of issues...
If the loud squealing wasn't there before you had the new PS hose installed it could be the wrong fluid or just low
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 14 Jun 2015, 08:16 am
Thanks for the info, the power steering fluid is full, so I'll check with the garage to see what they put in... I did notice drive belt is a little worn so I don't know if that's the problem.
Regarding the locks, I only have one key and today it took me 18 attempts to open the door as when I unlock the car and release the key the lock just drops down again.
Yet the lock button on the drivers door locks and unlocks all the doors with no problems... Any ideas?
Old 14 Jun 2015, 12:40 pm
Are you talking about the passenger side door?
Old 14 Jun 2015, 03:16 pm
Nope, the drivers side, none of the other locks work unless I use the button on the drivers door.
When I turn the key in the drivers side door, the lock pops up then goes back down again, the other locks make a sound like they're trying to move but don't.
I have to keep trying and usually after 10 or so attempts it will stay up and allow me to open the door.
Old 14 Jun 2015, 04:21 pm
I would suggest checking the 20 amp RKE fuse in the fuse box. Make sure you take the fuse out and clean the contacts.
Old 15 Jun 2015, 06:37 am
I checked all the fuses in the box with a multimeter, cleaned the contacts and it still has the same problem... Although today when I got to my car, I also found the battery had died and I couldn't switch the alarm off (until I completely disconnected the battery) it turned out the internal light doesn't switch off automatically anymore.
Old 25 Jun 2015, 02:00 am
On the headlight stalk you should have a small lever for changing the brightness of the instrument panel lights, the top position of this is a separate on/off switch for the big interior light. It could just be that.
Old 07 Jul 2015, 12:23 pm
Ok, late reply but that was the problem... a real Duh moment from me!
I have one other question, regarding the fact I only have one key and my local Chrysler service place wants 100 for a new remote... I saw this on eBay for 49
CHRYSLER PT CRUISER ECUs / TRANSPONDER / ALL LOCKS & 2 KEYS 00-10 | eBay
Is it easy enough to replace all these parts? Can you just switch over the ECU's and Transponders in the 2001 model? Is it worth getting this for that price?
2001 Limited, a couple of issues. Maybe related? Ether General PT Cruiser Discussions 7 23 Sep 2014 10:04 am
I need a couple Cruiser Quarterly back issues wwpptc Classifieds: Want To Buy 25 14 Apr 2012 08:49 pm
New Guy! Couple of Questions boothman Wheels, Tires, Suspension 2 31 Mar 2010 01:26 pm
A couple of questions ejstith General PT Cruiser Discussions 9 28 Aug 2009 11:13 am
Couple of questions JoeHundredAire Tech & Performance Forum 4 13 Apr 2009 07:06 pm
