Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Windows and inner fan stopped working
Like Tree6Likes
Old 19 Jul 2015, 11:45 am
Croiser's Avatar
Default Windows and inner fan stopped working
Imagine this, it's 38 C/100 F over here and my side windows stopped working, same as air fan, so I can't let any air into the cabin. Fuses are OK, everything else works fine. We will loose few kilograms while travelling, but please help...
2002 2.2 CRD Limited
Old 19 Jul 2015, 12:29 pm
Default Re: Windows and inner fan stopped working
Is your PT Cruiser a first generation? If so I would suggest doing the following diagnosis.
Is your airbag light on also?
PDC Fuse 3 feeds through C106 connector under dash, then to C1 connector (ignition switch run position), then to interior fuse block Fuse 5 (air bag run) Fuse 6 (back up lights/rear window defogger) Fuse 7 (HVAC blower fan) and to CKT BKR 2 (power windows).
Check and verify fuse #3,5,6 and 7 are good.
There has been some problems with pin 21 on connector C106, the wire going into and out of the connector was blackened and there was some signs of melting gray material on downside of connector related to pin 21 wire. Pull the connector apart and see if the terminals are corroded.
If they are corroded I would suggest scraping, cleaning and apply some dielectric grease to it. Put it together and pull it apart a couple of time to make sure its making good contact. If there is a problem here you might want to find out what is drawing enough current to blacken the wire.
If the connector C106 is good then I would suggest you check your ignition switch.
Old 19 Jul 2015, 01:16 pm
Croiser's Avatar
Thanks, mate! Yes, airbag light is on also, since windows stopped working.
Could you be more precise about those connectors (C106, C1,...), and PIN 21, where are they exactly? It's 2002 CRD Limited.
Yesterday I was washing my PT, but shortly, and the next time I've started it, those things stopped working.
Old 19 Jul 2015, 02:45 pm
Croiser's Avatar
I can see that user elgeep already wrote about it few years ago.
There's also picture from sanatanadharma.
Shame on me for bad search.
Old 19 Jul 2015, 03:05 pm
LionPT's Avatar
Not your fault...the search engine sucks
Old 26 Jul 2015, 09:42 am
Croiser's Avatar
What is CKT BKR 2 or where is it?
Old 26 Jul 2015, 09:47 am
Croiser's Avatar
Is it strange that there is no wire going to the fuse 3?
Old 26 Jul 2015, 10:03 am
Because Trump
Old 26 Jul 2015, 10:46 am
Croiser's Avatar
Now i get it. We've found it and opened, everything seems OK.
Old 26 Jul 2015, 04:40 pm
Let us know what you find on connector C106.
In the shop manual you can find connector/ground/splice locations at 8W-91.
You can find the fuse location by looking at the wiring diagrams.
AC stopped working realized Tech & Performance Forum 2 22 Jun 2011 06:06 pm
key fob stopped working twotone General PT Cruiser Discussions 10 17 Jun 2011 05:47 pm
dashboard stopped working Locks35 Tech & Performance Forum 3 03 Nov 2009 04:33 pm
My ac stopped working. Help!!! salena Tech & Performance Forum 3 14 Oct 2009 10:56 pm
