Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Replacement key in UK
Old 24 Sep 2015, 01:57 am
Default Replacement key in UK
Hi all
New member and new owner here. I bought a 2005 2.4 Touring less than 24 hours ago and love it already. I posted in the new members area with a photo already.
Does anyone in the UK have any experience buying a new key / transponder for the PT? Would like to have a spare but not sure of cost etc.
Regards,
Simon
Old 31 Oct 2015, 03:15 pm
Default Re: Replacement key in UK
Timpsons (in most larger tescos) will do you a working key for about 30. I got one a couple of years ago and it's still working fine. The key fob thingy is a different matter,I've still not got around to that.
Old 24 Apr 2016, 05:00 pm
uncomn's Avatar
I priced one last week at Jeep/Fiat they want 120 total for key, fobb and chipping it all.
2002 Touring 2.0 Steel Blue Pearl
2005 GT 2.4 Dark Plum Pearl
Old 21 Jun 2016, 08:02 am
Trillion's Avatar
Location: The place where the Game of Thrones accent comes from.
I've read on here that you can code a third key if you have two already. They look to be about 10 for a virgin key.
What software are the dealers using?
EDIT: Instructions for a third key here.
ALSO found this for coding a fob.2000 to 2005 models.
ATTENTION: You MUST HAVE one working remote to add one more to the system. If you do not have one working remote right now then these instructions will not work. You will have to have a Locksmith or dealership use a computer to program the first remote for you.
Click here to find an Automotive Locksmith in your area to program this remote.
1. Turn ignition to run position (as far as you can go without starting engine).
2. Using any Working remote, press the UNLOCK button for 4 to 10 seconds.
3. Within the specified 4 to 10 seconds, continue pressing the UNLOCK buton and press the PANIC button for 1 second and release both buttons at the same time. A chime will sound within 3 seconds to indicate that the vehicle has entered remote programming mode.
4. Within 30 seconds of the chime, press any button on all remotes to be programmed including previously programmed remotes. A chime will sound after each remote is programmed.
5. Turn ignition to OFF and remove key.
6. Test all remotes.
Old 26 Jul 2016, 11:35 am
The requirements to add an additional fob/transmitter refer to a panic button needing to be depressed, however my 2002 PT only has a lock and unlock button. Searched the internet and drawing a blank on how to add it to the system with only 2 buttons.
Any suggestions would be welcome!
Cheers
Old 27 Jul 2016, 04:31 am
Trillion's Avatar
Here's a thread from this site some years ago and it does say 2 keys are needed to program a third.
Cheap Way to get a new transponder key!
Old 27 Jul 2016, 11:53 am
Thanks Trillion, I do actually have 2 programmed already, trying to add a third. Nothing about how to do it with only 2 buttons though, sadly.
A friend gave me an old off market key fob (Identical to my original) they had so i took the inside out of the cracked case one i'm looking to replace and put it in the new, however, for some reason, it would not work! lol.
Old 27 Jul 2016, 12:01 pm
Trillion's Avatar
I'm still looking for 148hp CRD so I don't even have a car. But with the car I have right now there is a transponder chip that unlocks the immobiliser and an RF board that unlocks the doors by remote. I doubt you will be able to code a secondhand key it will have to be a new one.
Old 01 Sep 2016, 11:25 am
Trillion's Avatar
Seems there are some diagnostic tools that can code a key by pulling a 4-digit pin number from what must be the SKIM I should think. Still not got a car so can't try it. This video may be relevant
In the UK looking for a 2006 or newer CRD!
Top Replacement iBorg PT Cruiser Convertible Forum 4 03 Aug 2014 11:07 am
ECM replacement richardvan Tech & Performance Forum 8 30 Jul 2014 10:26 am
2001 PT - Engine mount replacement needed with Oil pan replacement? SanPT Tech & Performance Forum 14 23 Sep 2012 08:49 pm
Looking to buy replacement rim nacho_libre Classifieds: Want To Buy 4 03 Jun 2010 04:18 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
