Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Pt cruiser 1.6 idle not stable
Old 01 Sep 2016, 12:53 pm
Default Pt cruiser 1.6 idle not stable
Hi all
I have problems in my pt cruiser.
Idle seems not to be as stable as it should and when I start running the motor seems to go down and loose power.
I am not expert on it but I checked the 02 sensor with a OBD2 tools and it goes up and down all the time un idle
Is it normal?
Any help?
Thanks
Old 01 Sep 2016, 01:04 pm
Default Re: Pt cruiser 1.6 idle not stable
Be aware most members here have 2.4 engines.
Engine light on? If so what are the codes?
How many miles?
Has it gradually been losing power? If so you might want to check and see if your exhaust is restricted.
Old 01 Sep 2016, 03:05 pm
cruserdad1976's Avatar
just asking but
Year?
Miles?
what has been done?
Model well the 1.6 says it is not in the states.
where are you located?
PT cruiser overheat at idle Fable55255 Tech & Performance Forum 10 28 Oct 2017 08:11 am
2007 PT Cruiser rough idle J2007 Tech & Performance Forum 4 25 May 2016 09:36 am
PT Cruiser rough idle J2007 Canada PT Forum 3 25 May 2016 12:22 am
HELP...Cruiser sputtering at idle mahgninnuc68 Tech & Performance Forum 11 09 Mar 2012 07:02 pm
06 cruiser idle/fan problems TFD Tech & Performance Forum 10 10 Jul 2009 07:26 am
