Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Electric Window Stuck
  • 1 Post By barryfromwales
Old 19 Nov 2016, 12:05 am
Default Electric Window Stuck
hi
Pt Cruiser 2.2 diesel 2006 model
I was driving home from work and got pulled by the police so put the window down to talk... then aftert that, it won't go up. There's nothing going on. All the other windows work fine, it's just the drivers side window is stuck in the 'fully down' position
I realise it could be any number of things that is causing the fault so... any help is GREATLY appreciated (and go gentle... i'm a novice :/)
Old 19 Nov 2016, 08:25 am
Default Re: Electric Window Stuck
Not sure, but the first thing I'd check is the fuse box. Might be a popped fuse.
Old 21 Nov 2016, 04:54 am
thanks for the reply.
I took it to a friends and he stripped the door down and (luckily!!!) found that a wire had broken (by the motor) and we were able to connect it back up.
It seems that the up/down motion of the motor had, in time, caused the wire to wear/snap
rob302 likes this.
Old 21 Nov 2016, 07:27 am
Glad to hear it was a simple solution and you got it fixed. Happy PT'ing.
2006 window switch circuit burned with window stuck up? Amtrak23 General PT Cruiser Discussions 14 04 Jul 2016 03:52 am
2007 driver power window failure/window stuck down JeffLancia Tech & Performance Forum 5 30 Nov 2015 10:26 pm
stuck window djgroove General PT Cruiser Discussions 0 31 Oct 2012 07:32 pm
electric window issue puddingmobile PT Cruiser Convertible Forum 2 10 Aug 2011 08:12 pm
removing electric window switch gonzomania Interior Accessories Forum 10 16 Mar 2004 07:40 pm
