Hi Guys,
Anyone tried a diy type scan tool on the SRS system of a Mk 1 (2003) UK market CRD car? I've had a topdon elite maxiscan which wouldn't read the ecu and had to be returned, though it would probably work on a US model. The snap-on scanner with the individual chips wouldn't read it but my usual garage say theirs is rubbish and hardly ever reads anything anyway. I'm currently looking at this one but ideally would like to hear from someone who's tried it: Autel MD802 All System Elite Maxidiag OBD2 Graphing Diagnostic Tool Scanner I already have an autel scanner for engine diag which does work ok and obviously doesn't read the SRS or ABS systems. So far I've only seen mk2 coverage for the MD802 on their website. What tried and tested alternatives are there for say under £200? Any help gratefully received, I know this is fairly expensive for diy but when you factor in fuel and so on , it's only about 3 scans worth so may well be worthwhile. Thanks. Tom Last edited by Alfie1; 06 Jan 2017 at 06:35 pm. Reason: clarity |
As a follow up to this, I have now purchased an autel maxidiag MD802 which does indeed read and identify the airbag codes - in my case 'P1200 - driver side curtain or seat squib circuit open' so, yes it does work and it was £162 incl.
Autel is great option, same with LAUNCH
stay away from snap-off
2003 GT M/T in Onyx Green Pearl on Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17. Dark Slate Gray Interior. OEM cargo net, parcel shelf, slush mats and trunk protector, mud flaps, mopar subwoofer. Platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover. Generic lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit. Urethane insert engine mounts. Energy suspension full body urethane bushing kit. Chrysler premium front speakers, Jenson 6x9 rears. Boston Audio 4x55W amp. Panasonic head unit with xtenzi bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter |
My problem was a P1200 for the intermittent airbag light.Drivers side curtain or seat squib circuit open(or similar) Removed battery and left for a few minutes. Reseated the yellow airbag connectors under the seat, unzipped back cover and did same at side of headrest - still no difference, maybe light showing not quite as often as before.
Got serious and took front seats out (easy),unzipped cover again and removed wire from base of seat to seat airbag. Wire is enclosed in split concertinaed plastic tube. Took it out of this and put extra insulating tape on bits of the wiring. Put tubing back over it and routed it carefully and away from metal seat frame. Reassembled and jobs a good 'un. Done about 500 miles since. I think that the plastic tube covering the wire was not staying closed all the way up due to the routing of the wire and touching the seat frame, Hopefully that's the last I'll see of this problem. Last edited by Alfie1; 17 Jun 2017 at 09:15 am. |
been looking at these but the all system one ,
how have you been getting on with yours ? have you tried it on other types and makes of cars ? im just abit concerned that it costs 100usd each year to get the updates , if you dont update it do it stop working after a certain amount of time like some of them do or will it still work ? |
Problem returned after a week or so, stripped seat and took that part of the loom out again. checked for continuity and found a break in a wire. Repaired and soldered, hopefully all good now.
With regards to the scanner, yes it's 100 dollars a year for updates but I would imagine that means mainly for post 2017 cars as they come out, it should still work for earlier ones without the updates. As yet I haven't got around to trying it on my other 'new enough' car. The other is far too old for electronics. Tom |
As another update to this, up to now the problem still hasn't returned so the scanner worked well for me, I only kept it until I was happy that the problem had gone and then ebayed it for what I had paid, as there was still 10 months on the original year until update possibly required. If needed I'd buy another and do the same again as my cars are too old for airbags (and even diagnostic sockets) and I have no interest in modern cars at all.
Tom |
Thread Tools | |
Display Modes | |
Diagnostic Scan Tool/Code Reader | njsteve1 | Tech & Performance Forum | 19 | 14 Aug 2016 10:29 am |
bought new scan tool, ABS communication trouble | jdlmodelt | Tech & Performance Forum | 6 | 17 Oct 2014 01:37 pm |
OBD Scan tool compatibility | AndrewJ | Tech & Performance Forum | 0 | 23 Feb 2012 06:17 am |
OBD Compact Reader Scan Tool Question | sinbad2050 | General PT Cruiser Discussions | 3 | 26 Mar 2011 01:10 am |
Scan Gauge II | ucantcme | Classifieds: For Sale/Trade | 0 | 14 Oct 2008 07:49 pm |
