Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Top Hose cooling
Old 23 Jan 2017, 06:45 am
Default Top Hose cooling
The cooling fan can play silly buggers now and again, so going to fit a rad switch connected through a relay to the yellow wire on fan. Any one know the internal diameter of the top hose?, fitting in line alloy (on UK ebay) tube with switch. 2002 2Lt petrol cruiser. Thanks in advance
Old 23 Jan 2017, 10:29 am
Default Re: Top Hose cooling
Here at the Stars and Stripes the radiator fans last about 100,000 miles and the brushes are worn out and replacement is best. I'm not sure if the UK fans are the same.
As the brushes are about to fail the cooling fan will work sometimes before complete failure. Our fans have a low speed for cooling and high speed for cooling/AC condensing for the air conditioner.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 23 Jan 2017, 10:43 am
Thanks for that,but I cleaned up the relay contacts on the original and it worked again. I just want to fit the switch as a fail safe
Turbo Coolant hose? Replacement/Hose Size PTTuber Tech & Performance Forum 9 07 Aug 2015 05:27 pm
Hose help!! schnooks General PT Cruiser Discussions 4 29 Nov 2014 06:57 pm
What hose is this? django General PT Cruiser Discussions 11 31 Mar 2014 06:56 pm
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
What is this hose? 01limited94 General PT Cruiser Discussions 4 14 Mar 2013 07:57 am
