Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
Clutch and Brake fluid :confused:
Old 29 Jan 2017, 10:56 am
Default Clutch and Brake fluid :confused:
I've got a problem with the clutch on my 2.2 Diesel 2006 Cruiser.
Intermittently it sticks... unable to change gear or it stalls (like there is no clutch at all, if that makes sense)
Also, I am losing Brake fluid... I haven't checked for any obvious leaks as yet but I was wondering if the two faults are connected?
Any help would be appreciated. Thanks
Old 29 Jan 2017, 12:23 pm
Default Re: Clutch and Brake fluid :confused:
Well, both the clutch master cylinder and brake master cylinder take brake fluid. Are you sure they're BOTH losing fluid and you're not just looking at one or the other and thinking it's for both? I don't know, just asking. There's also a clutch slave cylinder that COULD be leaking. That's usually the source on the clutch problems with fluid loss and not the master.
Old 29 Jan 2017, 12:34 pm
How rapidly are you using brake fluid? It is normal for fluid level to go down as pads wear, that is not a "loss". New pads will bring level up again.
Brake Fluid ? red98gt Tech & Performance Forum 5 10 Jun 2016 02:19 pm
Hissing near brake fluid reservoir ptkwt General PT Cruiser Discussions 5 09 Jul 2014 04:09 pm
Picture of clutch fluid reservoir cap ? rasec8711 General PT Cruiser Discussions 19 30 Dec 2013 09:35 am
Brake Fluid interval discovering06 Tech & Performance Forum 2 10 Jul 2013 01:01 pm
flushing brake fluid bugatti Tech & Performance Forum 18 26 Mar 2011 12:27 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
