![]() Quote:
what about this one?
https://www.ebay.co.uk/itm/Integrate...-/391399658051 Obviously, I would be looking for one that doesn't require dealership programming. |
![]() Quote:
![]() Quote:
It's plug-n-play, just follow the simple included programming instructions. Here are the Dorman TIPM installation instruction: https://www.dropbox.com/s/f39dr85vbn...tions.pdf?dl=0
![]() ![]() '06 Touring Edition NA Automatic 155k Miles / Electric Blue Pearl USMC '82 - '93 Last edited by rckstein; 14 Apr 2018 at 06:17 pm. |
Barry; The 'dropbox.com' address above from Rickstein is interesting info. The parts manual for a 2006-2008 PT shows 2 TIPMs. one for a convertible. One for a wagon.
If the headlight is the only problem you have, I'd open the TIPM and look inside to see if there are signs of water stains. If not, yours is probably just as dependable as any other used/reman unit you would install. Which brings up the question, what do they do to it call it a reman? |
![]() Quote:
When I bought the Dorman, I opened it up to see the inside and this is what I found: ![]() ![]() Everything on the circuit boards is sealed under some sort of an epoxy or other compound that helps to keep the circuit board and components protected from water intrusion. In the above pic, near the bottom edge of the circuit board you can see the sealing compound. So if they "remanufacture" these TIPM's, how would they remove the sealing compound to replace any board components, without actually destroying the circuit board? In my opinion, they basically have to replace the entire circuit board with a new one, with new components? Also, I can't see them reusing the case as the Dorman one that I got was in a new case. So if it's all new components, then again, what do they "remanufacture" on these, and why do they need a core back if they don't reuse anything?! Inquiring minds would like to know. I would like to get in contact with a company that actually does any "remanufacturing" and ask them. ![]() When I removed the old TIPM from my PT I also opened that one up as I wanted to see the condition inside. The 11 year old TIPM was just as clean and nice inside as the new one. There was no evidence that any water had ever gotten inside the case, so that's a testimony as to how well sealed these must be. ![]()
![]() ![]() '06 Touring Edition NA Automatic 155k Miles / Electric Blue Pearl USMC '82 - '93 Last edited by rckstein; 15 Apr 2018 at 08:26 am. |
![]() Quote:
I now think that the refurbishing is as simple as re-flashing the unit. The programming on them likely becomes corrupted and a simple reflash is all that is done to refurbish them. |
![]() Quote:
![]() So it could be: (1) that DORMAN "remanufactures" them for MOPAR, or (2) MOPAR just buys the replacement DORMAN top covers to supply with their units. But I don't think it's (2) because I had bought a replacement MOPAR top cover and it did not have the DORMAN name on it. So MOPAR does make their own top covers and if they remanufactured the TIPM's themselves, then they would most likely supply their own plain top cover with their TIPM's. So it must more likely be (1), that DORMAN "remanufactures" them and puts a MOPAR sticker on them and a DORMAN top cover. But the label on the box from the MOPAR TIPM says it was "Made in Mexico" ![]() This is just too confusing, how a DORMAN top cover got on a MOPAR made part? ![]() But one thing I don't like about the DORMAN top cover is that it does not have the fuse legend on the bottom side of the cover, like the OEM cover does. The DORMAN just gives you the fuse location # then you have to refer to the Owner's Manual to see what location controls what circuit. ![]() On the underside of the OEM cover, it has the fuse # as well as what circuit it controls. Had I known this, I would have kept the OEM top cover and not have sent that in with the core. I wish I could find an OEM top cover with the legend, but even the new OEM ones now only come the same as the DORMAN, with just the fuse #. ![]()
![]() ![]() '06 Touring Edition NA Automatic 155k Miles / Electric Blue Pearl USMC '82 - '93 |
The good news is that you have a genuine authentic Mopar cardboard box!!!
Did some snooping about TIPMs last night and found some interesting info. from 3 different sites. RPM Extreme .com reprograms them. TSB 08-021-06 - shows that TIPMs can be reset for the tail/signal lights. The trucks pulling trailers that short out their lights are screaming. And I don't blame them for not buying another Dodge truck if the dealer charges them a grand to fix a taillight. Plowsite.com claims that the same TSB flash will turn on non working headlights. You Tube 'Dodge headlight problems' -- 'don't waste your money' also has a car owner [female] who tells an interesting story about her Caliber headlights. I'm able to change headlight on or off when I open the door with the remote. While in the front seat. With a few touches of a button. The pay-in doesn't stop. |
Tags |
tipm |
Thread Tools | |
Display Modes | |
06+ TIPM 06-10 TIPM 719AN | 808bruiser | Classifieds: For Sale/Trade | 0 | 01 Aug 2017 02:57 pm |
Thought it was a TIPM problem but… | KurtFoldUp | General PT Cruiser Discussions | 4 | 04 Oct 2015 08:15 am |
Dreaded MFS issues | PTN | General PT Cruiser Discussions | 9 | 02 Sep 2013 08:12 pm |
the dreaded new fan | red06limited | Tech & Performance Forum | 9 | 05 Jul 2010 06:22 pm |
