Hi,
Does anyone know what torque the three bolts on the thermostat housing should be tightened to? Can anyone suggest a decent long life coolant/antifreeze ? I know it is a HOAT coolant, but unsure of a suitable brand. CommaXHD G05 with Ethylene Glycol and Nitrile for trucks and vans with wet liners is the best that I have found so far(if compatible). Thank you |
From 2006 manual, this is the information I used.
2.2L DIESEL ENGINE WARNING: Use extreme caution when engine is operating. Do not stand in direct line with fan. Do not put your hands near pulleys, belts or fan. Do not wear loose clothes. 1. Clean all sealing surfaces. 2. Position and install thermostat housing (2). Tighten bolts to 9 N·m (80 lbs.in.). NOTE: Inspect condition of all clamps and hoses, replace as necessary. 3. Connect coolant hoses and by-pass hose. 4. Connect coolant temperature sensor electrical connector. 5. Install generator (Refer to 8 - ELECTRICAL/ CHARGING/GENERATOR - INSTALLATION). 6. Close coolant drain. 7. Install engine cover (Refer to 9 - ENGINE - INSTALLATION). 8. Connect negative battery cable. 9. Fill coolant system to proper level with appropriate coolant mixture (Refer to 7 - COOLING/ENGINE/COOLANT - STANDARD PROCEDURE). 10. Start engine and inspect for leaks. Last edited by Alfie1; 22 Oct 2018 at 02:28 pm. Reason: awful English, sorry |
![]() Quote:
If at First You Don't Succeed - Try, Try Again |
Thanks Alfie1 for the detailed reply, that will help a lot.
Ptcruisersteve, My pt is a 2004/5 on a 54 plate. I think it technically means from September 2004 to February 2005 first registration;so a 2004? Thanks for the replies. Does it make a difference? Last edited by mulder66; 24 Oct 2018 at 06:11 pm. |
Hi, having checked my v5c doc for my cruiser it is in fact a 2005, so you were correct ptcruisersteve.
I am still looking for a suitable coolant Cheers |
I use this Mulder - from German maker Mannol (use their oils as well)
https://www.amazon.de/gp/product/B073V6VQG6 We need the -40 sometimes over here ![]() If you can't get Mannol in the UK, just match the main spec (ie: mb325.3 - the Mercedes spec) on something else and you'll be OK.
_________________________________________ '07 2.2 CRD Last edited by Sinbad; 25 Oct 2018 at 02:39 pm. |
While I'm at it - after much hunting - I went with this for the gearbox.
This matched the Toyota spec which matches (or might even slightly exceed - can't remember now ![]() https://www.amazon.de/gp/product/B00HW8NPDC
_________________________________________ '07 2.2 CRD |
Sinbad
Thanks for the reply All the best Mulder66 Last edited by mulder66; 26 Oct 2018 at 12:20 pm. |
Checking on the Comma site when I enter my car's reg it lists G48 as the correct/suitable coolant for my car. This is however, mb 325.0 not 325.3. Given that I do not know of any important distinction between these two, I will likely use the Mannol unless anyone knows better.
Cheers P.S. Sinbad: where did you find the info regarding the coolant compatibility? I couldn't find anything in the handbook. Last edited by mulder66; 26 Oct 2018 at 01:07 pm. |
Thread Tools | |
Display Modes | |
Car temp climbing after thermostat and thermostat housing replaced. | superjew78 | General PT Cruiser Discussions | 23 | 04 Jun 2014 02:37 pm |
Thermostat housing problem | SugarSana | Tech & Performance Forum | 7 | 09 Jan 2013 12:18 pm |
Replaced Thermostat 06 PT Getting Engine Light ERROR P0128 Coolant Thermostat | aluisi | Tech & Performance Forum | 1 | 20 Nov 2012 06:47 pm |
Thermostat housing | cowboyinboxers | Tech & Performance Forum | 11 | 20 Oct 2012 06:51 pm |
01 leaking from Thermostat housing, Please help | gdarst | Tech & Performance Forum | 11 | 06 Jan 2010 06:52 am |
