I attempted to replace the stock 9005/9006 headlight bulbs with PIAA Super Extreme White bulbs but I can get them in the socket. The stock bulbs have a connector on the back, but the PIAA's (and all other replacement bulbs that I've found) have the connector turned at 90 degrees. The connector then conflicts with the surrounding metal housings and I can't get the wiring harness on. How does one go about replacing the stock bulbs?
Gary - I had this problem when putting in my blue high beam bulbs.
Each bulb has 3 tabs, one smaller than the others. The driver side bulb can only be inserted at 4 oclock and locked in at 6 oclock, but the metal housing is in the way. I ended up taking a hot knife to one tab on the drivers side bulb, making it smaller. That way I could insert the bulb with the 90 degree end at 10 o'clock and locking in at 12 o'clock. BTW, First I lined it up by eye to see which one needed to be cut. Hope this helps....Oh and im jealous!! Those are supposed to be sick bulbs! |
http://www.ptcruiserlinks.com/forum/...chTerms=9005xs
And this may also be helpful http://www.jeepsunlimited.com/zj/piaa/headlight.htm
Thanks guys. I found out from ptdoityourself.com that the bulbs are XS (straight connector), Doah![xx(]
I ordered Street Glow Xenon's today, so that should solve the problem.
2003 Electric Blue PT Cruiser GT 5-spd MOPAR Stage 1 kit Custom Stage 1 emblem on rear hatch Greddy Turbo Timer AGP factory surge valve blockoff plate AGP/TurboXS Type H-RFL BOV 160 degree thermostat Magnacore plug wires Champion RE14PLP5 Double Platinum plugs gapped .050\" Screamin Demon coil Momo shift knob 3 gauge pillar pod with Autometer Lunar boost, EGT and oil pressure gauges Stewart Warner Shift Light Streamline Designs third brake light overlay \"Turbo Cruzer\" Rear splash guards Rear spoiler Hidden Hitch Ichiban pedals Streetglow Xenon headlight and foglight bulbs PCV line oil seperator Firestone Firehawk SZ50 215/50R17 tires PT Tuning axle back exhaust and muffler Mr. Dyno vehicle performance computer Pioneer DEH-P77DH AM/FM/CD Kenwood KSC-WA62RC The WooX 30w x 2 powered subwoofer
Some more bulb advice --- make sure that you don;t OVERWATT too much ... the OEM bulbs are rated at 55W... many of the superwhites and blues are rated much higher, especially the high beams (100w) ... these can easily burn out your wiring harness, a $300 repair. You can find 55W and 65W superwhites and xenons from Midnight Moose (that's not a plug, just a suggestion).
I have superwhite 55w for my lowbeams, and the xenon blues for my high and foglights ... the highs are also 55w, but the fogs are 65w. |
| GE Nighthawk Headlight Bulbs | rszappa1 | Tech & Performance Forum | 13 | 11 Nov 2004 06:16 am |
| Xenon headlight bulbs | Art Rigby | Tech & Performance Forum | 7 | 18 Aug 2004 12:55 pm |
| Problems with Headlight bulbs | KingKole02 | Exterior Accessories Forum | 18 | 26 Mar 2004 11:46 am |
| ..headlight bulbs and adjustment.. | earringboy | Tech & Performance Forum | 17 | 30 Dec 2003 05:14 pm |
| What are the best & brightest headlight bulbs? | ptkid | Exterior Accessories Forum | 6 | 08 Oct 2003 09:58 pm |
