Ground Effects
Old 25 May 2007, 01:55 pm
Windancer's Avatar
Default Ground Effects
To All
As I mentioned in an earlier post, I now have a PT Convertible as my second vehicle. I have looked a many of the aftermarket parts sites and it is overwhelming to say the least.
I really want to add the Chrysler PT Body Kit which is basically 2 pieces of plastic to both the front and back bumpers as well as the side panels. After doing some research, I see that pretty much all of the aftermarket parts are attached using 3M double sided tape.
I'm interested in hearing opinions on the application of add ons using this two sided tape. In talking to my dealer, who hasn't really done much of this, did tell me that they had trouble with one PT that the owner had the same thing installed.
One thing to keep in mind that I live in the heart of the Canadian Prairies where winters can be very cold. Still unsure if I will even drive this in the winter but it will be exposed to temperature extremes.
Thanks in advance for any insight that you be able to give.
Regards
Terry
Old 26 May 2007, 10:03 am
Default Re: Ground Effects
I suspect it would work fine, the stock door guards are attached with double-sided 3M and they stay on fine.
In fact they're a real pain to remove!
Nothing could be finer than cruisin' the Carolinas!
http://www.carolinaptcruisers.com
Old 28 May 2007, 08:01 pm
I have worked with body kits/ground effects for years. 3M makes a VERY good tape. Works in extreme cold and hot. I do however recommend 3M #6394 attachment tape. It's .090 thick, which is alittle thicker then the usual. You can only get it through a body shop.
Bumper cover (Ground effects) Grayscruiser Exterior Accessories Forum 13 24 Oct 2009 03:05 am
mopar ground effects and probably keeping the car VellianPT General PT Cruiser Discussions 1 08 Apr 2005 10:44 am
OEM Ground Effects! 1lowufo Exterior Accessories Forum 5 13 May 2004 06:17 pm
'WANTED' ...OEM Ground Effects! 1lowufo Classifieds: Want To Buy 0 25 Apr 2004 06:27 pm
OEM Ground Effects 1lowufo Exterior Accessories Forum 3 24 Apr 2004 07:48 pm
