PT Cruiser Forum Car Videos
Custom Wheels
Removed front License Plate
Old 10 Jul 2007, 08:16 pm
oldcoach's Avatar
oldcoach oldcoach is offline
Default Removed front License Plate
Removed front License Plate, how to repair holes in bumper?
Old 22 Jul 2007, 05:05 pm
03TurboGT's Avatar
03TurboGT 03TurboGT is offline
Default Re: Removed front License Plate
Poly filla for drywall repairs and duplicolor? I'd try it.
Bryn-
'03 Turbo H.O.
with K&N Intake
Stage 2 Jet Chip
NGK Iridium Plugs
Xenon Headlights
10.5mm Racing Wires
Mopar BOV Conversion
4 Drilled/Slotted Rotors
180W Infinity 6.5" 2-way's
General Performance 215/45R 17's
Mopar/Borla Dual Cat-Back Exhaust
Old 23 Jul 2007, 07:07 am
Johns Steel Blue's Avatar
Johns Steel Blue Johns Steel Blue is offline
Couple of ideas here..
Fix The Holes
John
People say I have a drinking problem. I Drink... I Get Drunk... I Fall Down... No problem! ! !
Old 27 Jul 2007, 03:53 am
oldcoach's Avatar
Thumbs up Re: Removed front License Plate
Thanks for the info,let me make this look good
Old 27 Jul 2007, 12:28 pm
bobs turbo pt bobs turbo pt is offline
post pics when you are done good luck !!
Old 19 Sep 2007, 02:00 pm
dolemite dolemite is offline
*Cheap mod alert* I used a 2 buck license plate bolt kit from Target - 4 black nylon bolts with chrome snap on caps.
I also tried some generic Chrysler mushroom push-in plugs from Pep Boys, flat black. You could probably use touch-up paint on these.
Either way is an easy, cheap fix. Cheapness Rules
'06 PT Limited Edition, Linen Gold ext./Pebble Beige int., K&N air filter, Mobil 1 synthetic/K&N oil filter, Crane FireWires & Bosch Platinum 2 plugs, (25 mpg in town - yeah!), Ventvisors, Spoiler, full length Husky Liner, Anti-Microbial cabin air filter, Wheelskins leather steering wheel cover, front ceramic pads & new front rotors, Clarion underseat powered sub, Premium Chrysler emblem mats, stubby antenna, back bumper scuff guard, front windows & windshield tint, 8-ball stemcaps, 8-ball door lock stems, 8-ball cigarette lighter, Rat Fink & NA decals, diamond in the back, sunroof top, diggin' the lean with the gangster scene, mm-hmm..
Old 20 Sep 2007, 02:01 pm
Windancer's Avatar
Windancer Windancer is offline
Might not be the best repair but this may work. Several years ago, I fixed a small hole in a friend's rotomolded plastic kayak by using a hot glue gun and "injecting" the glue (slow setting stuff) into the hole in the hull and then while the glue was setting, I put some paint on to to match. Then some light sanding after it dried and another coat of paint.
Regards
Terry
2005 PT Cruiser Convertible - Touring Edition
Mopar Spoiler, Mopar Ground Effects Kit,
16x7 American Eagle Chrome 5 Spoke Wheels
Toyo Proxes 4 225/50/R16 High Performance Tires
Old 15 Dec 2007, 09:50 pm
dklipfel dklipfel is offline
Removing two 1/4 inch license plate holes is a purely visual desire. Beware of sanding. Even f successfully filled (easier said than done) it will probably result in a 1/l4 inch hole becoming a 1 inch diameter sanded spot. Now its really visible! Frequently the paint on a plastic bumper is NOT the same paint as that on a steel body. It may be the same color, but the base ingredients are different so as to accomodate plastic (different thermal expansion, different adhesion, flexible, etc). Not to mention the clear coat . . . .
Dave, 2006 PT GT,Linen Gold, fully loaded
Old 16 Dec 2007, 01:55 pm
soonercruiser's Avatar
soonercruiser soonercruiser is offline
Exclamation Re: Removed front License Plate
On soonercruiser, last year, the dealer put holes in the front bumper. Fortunately, we were putting the PT bumperette on it anyway.
With the new black vert I just got, I wanted a pure, clean front bumper. I tried some screw-in buttons, but didn't like them. So, I decided that I would attempt a comprehensive repair. My thinking is that, this time, black should be easy to repair, and I am going to get the 3M film on the front bumper in order to avoid all the hours of repairing paint chips, like I've had to do on soonercruiser. The film should mask out any minor imperfections in my job.
So, I used an Exacto knife to cut into the edges of the hole, so no urethane edges was sticking out or up in the air. Then, I did several body putty repairs, sanding, a then repairs again, and sanding. Then I aggressively buffed the paint in the area surrounding areas; and finally painted with the Chrysler OEM repair paint, using a piece of cardboard with a oblong hole shaped like the bumper to avoid overspray.
The weather got ugly here this week. The general spay paint quality looked good to me. So, I left her highness in storage for the paint to cure well. When it gets warmer this week, I will probably get her out Wed or Thur, buff out the paint a little more; then Meguires 1, 2, 3, and wax in prep for placing the 3M film in January.
Will post pictures of the next 2 or three steps.
Old 19 Dec 2007, 10:09 pm
Here are the follow-up photos
The first one is a full bumper view after spraying the base coat and clearcoat.
PT Cruiser World
Last edited by soonercruiser : 19 Dec 2007 at 10:46 pm. Reason: correct url activity
vB code is On
Front license plate placement spicy pt Exterior & Interior Styling 39 04 May 2008 11:15 am
Question: Front mounting license plate bracket for '07 pittsharrison Exterior Accessories Forum 2 13 Jun 2007 06:59 am
front license plate Jimbo General PT Cruiser Discussions 22 13 Mar 2004 05:49 am
Front License plate revisited.... tezz General Turbo Discussions 1 07 Oct 2003 03:26 am
Front License Plate turbomangt General PT Cruiser Discussions 8 04 Dec 2002 02:46 am
Archive: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  Internet Advertising | Personal Loans | Loans | Bad Credit Mortgages | Mortgages
