Window vent visors
Old 27 Dec 2007, 01:47 pm
Default Window vent visors
I was lucky enough to get a set of the in-channel vent visors for Christmas (not the ones that stick on the outside with adhesive).
I love the way they look, but I have one problem with them. When I roll the front windows up, the window hits the bottom of the visor, preventing it from going up. I know it's the right set, he got them from a Cruiser site.
I know the rears were installed properly, because they had instructions with them. The fronts didn't have instructions, but look & feel like they are seated properly.
Anyone else have these? If so, any suggestions?
Old 27 Dec 2007, 03:39 pm
prettybluewoody's Avatar
Default Re: Window vent visors
I've got the same problem, and mine DID come with installation instructions for both front and back windows. The rear two are fine, but one of the front ones has that same window-catching thing. (At the back edge of the window, right? Just in front of the 'B' pillar.)
I tried actually sanding down that corner of the visor just a little; it seems to have helped some, but it still catches about a third of the time.
prettybluewoody
2003 Limited Edition PT Cruiser:
Electric blue with Moss Motors 2-tone ABS woody panels, assorted woody touches here and there and a custom electric blue keyfob
Old 27 Dec 2007, 03:53 pm
Yep, that's EXACTLY where they hit. It's rather annoying, I don't want to have to move the visor every time I roll the window up. Like I said, I really like them, and like the way they look.
I'd thought about sanding a bit of a taper in, but wasn't sure if that would help. I wonder if a bit of adhesive to keep it firmly out would help?
Old 27 Dec 2007, 11:15 pm
for a customer with an f-150 who had the same problem, i made a couple simple wedges or ramps rather from some scrap plastic laying around, secured it in the channel with some doublesided tape. no more hangup, customer loved it.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 29 Dec 2007, 10:26 am
Hey Cartman: is there any way you could put up a picture of what you did? I can visualize how some sort of shim would work with the EXTERIOR-type visors, but not with these IN-channel ones! (Seems like putting something else in there would worsen the problem, and just be something else for the window to hang up on.) Thanks!
prettybluewoody
Old 29 Dec 2007, 10:05 pm
I would post a pic, but it was a customer vehicle that came in months ago. It was just two tiny pices of clear plastic (one for each side) from a broken bugshield about 1/2 inch long and narrow enough to be hidden in the channel. used a belt sander and made them tapered to a nice point, then stuck em in the channel butted up against the visors with some clear double sided tape. now that fix worked great because of the design of the ford window channel, and it may not work as well with these style channels because the ramps would have to be very slim. tryvelcro's idea of sanding the visors may be the best way to go, as long as the sanding is confined just to the hidden leading edges of the visor and the same ramp is employed. I do plan on purchasing the in channel visors myself, and if i run across the same problems, ill post my solution.
Old 30 Dec 2007, 10:55 am
Yeah, the sanding is what I've already done: right where the window glass hits the visor. It's not visible, just a little bit of a taper sanded in there. It helps a lot, but the glass still jams against the visor sometimes. So it's better, but not perfect; and I'm thinking of sanding it just a touch more.
prettybluewoody
Old 30 Dec 2007, 11:20 am
I didn't run into that with my PT, but I did on my wife's mini-van, and those are REALLY long. I took them out and re-inserted them - that did the trick. Took several tries, but they've been fine since.
Window problems misfitwife PT Cruiser Convertible Forum 7 15 Aug 2011 01:06 pm
Broken rear quarter window! littledog General PT Cruiser Discussions 12 20 Jan 2005 09:20 pm
Weird hatch window replacement problem! SRG Tech & Performance Forum 6 20 Jan 2005 01:39 am
Leaky rear window washer Jimbo General PT Cruiser Discussions 2 02 May 2004 09:33 am
weathertech window visors cruisergt Exterior Accessories Forum 3 23 Apr 2003 10:05 pm
