Help on Installing LED Mirrors on My 06 Cruiser
  #41 (permalink)
Old 16 Mar 2008, 12:08 pm
Default Re: Help on Installing LED Mirrors on My 06 Cruiser
On the passenger side, the '06-'08 signal wire is the white wire with the yellow stripe. I'm still trying to figure out the motor wires. I got left and right to work, but up and down are reversed... I haven't had a chance to open up the drivers side. I've got some errands I have to run, so I have to pick this back up later.
2007 Touring Edition - Marine Blue Pearl
  #42 (permalink)
Old 16 Mar 2008, 05:59 pm
white's Avatar
Finding the left or right turn sig. wire is easy because you can pull the tail light and look. My trouble was the power mirrors stuff. Never did get the right wires figured out and ran out of fuses (next time I will buy 2 boxes of fuses) (a person can't let little things like this stump you). My Haynes manual does not show the wireing dig. for the power mirrors, but then again, maybe that would not help either because we don't know if the Chinese wired them right anyway. Instruction sure would have helped.
And then the seller had the guts to right up a real nice report from me befor he even shipped the mirrors. Rinky Dink, that is what car salesmen try to do sometimes. Get thier browney points before they screw you over. O Well
E. White
2010 Black over Silver, Couture Edition
  #43 (permalink)
Old 16 Mar 2008, 10:46 pm
I thought the PT was made in Mexico... so the blanco con anaranjado is the passenger side wire.
I'm really not falling in love with these. I got the passenger side installed, but they are not big enough, and at full left it's still not aimed correctly. The lights are cool, but they are a little weak. I think I might dismantle these and put the light pods in the OEM mirrors. Either that, or I'll just buy the chrome mirror caps, and install lights into those. I don't know, because I still want the forward facing signals.
The style is cool for sure, but I'd rather have function over form right now.
If the angle was better and the mirror was bigger, and the lights were brighter, then they would be great, but that's what you get for $36 I guess.
To find the wire, I checked what wires went to the tail light, and tested each for voltage that allternates with the signal, then went to the wire channel running along the sills and tapped into the wire there.
To get the wire through the door, I pushed the grommet out of the sheet metal and made it straight, and pulled the wires through using a wire coat hanger, then pushed the grommets back on.
  #44 (permalink)
Old 17 Mar 2008, 11:03 am
white's Avatar
You are right. The new mirrors are small. If the one you have on does not turn enough you can turn it by hand, or have you tried that? Are your powered? If they are powered do they work that way? That has been my problem with blowing fuses.
I also thought of just taking the new LED ones apart and installing the LEDs in my old original units. Should not be too hard because they just used silicone to hold the LEDs in anyway. Will try to get happy with the drivers side one that is installed a couple more days and then see what to do
E. White
  #45 (permalink)
Old 17 Mar 2008, 12:54 pm
I have the powered ones from genkituning (see post from a little back) and the passenger side is just angled wrong. At the limit of the mirror motor's adjustibility it is still not enough. I'm going to investigate installing the light pod in the bigger OEMs.
  #46 (permalink)
Old 17 Mar 2008, 11:21 pm
outfit's Avatar
Send a message via Yahoo to outfit Send a message via Skype™ to outfit
Wow ..Yal are right on the light being dim... It is do able.. So far the angle on mine is okay..I have looked for different types of mirrors and am looking into putting in dif leds in the mirror.. CAn yall do that to yours???? I be sure to let you know how it comes out..May end up buying new ones...
<---- Just installed.
2006 PT Cruiser Touring Non-Turbo
3 -Hyper White Thin Flexible 5mm LED Dome Lights from Oznium Damn they make a dif in the inside ,let me tell you the best led lights you can buy
1 -Hyper White 921 Superstar Bulbs from Autolumination
1 -Hyper White T10 Wedge 194 (Lic Pllate) Super White LED from Autolumination
Pioneer Head unit W/ HD & Satellite radio
2 - 7inch DVD/Headrests Monitors... dvd players built in the headrests
HID Lights 8000k 9006 for lows from xhidoutlet....
HID Slim 55w 6000K for high's from HIDGEEK.
  #47 (permalink)
Old 18 Mar 2008, 12:39 pm
white's Avatar
OK here is what my drivers side mirror looks like. And you are right, the LEDs are not very bright (OK for night but dull for daytime). tn_Picture16-08 057.jpg
E. White
  #48 (permalink)
Old 18 Mar 2008, 05:25 pm
outfit's Avatar
That is th same type of Mirrors I have with the exception of the lens color..Mine is a Smoke color....
  #49 (permalink)
Old 21 Mar 2008, 08:26 pm
I uninstalled these and put my OEM's on. It's just not my style. I am selling the set I have for the same price I paid. (Since they're not used.)
I paid $35.98 so I'm willing to send them out for $35 including shipping. (they are the exact same ones that {white} has. Let me know if someone wants to buy them, let me know.
Maybe someone can use these to take the LED's out and install them in the OEM mirrors.
  #50 (permalink)
Old 26 Mar 2008, 02:26 pm
I originally had this about a year ago. A mail box helped me uninstalled them (vehicle abruptly pulled out across street, sending me into the mailbox).
I never hooked up my Ambers.
The switch idea is a good idea. Because were I'm from, the cops don't like blue LED's, so I have to be careful. Help idiot drivers know when you are switching lanes.
Yes a much needed addition to future cruisers.
Kingkole02
Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics
2004 Chrysler PT Dream Cruiser Series 3 skylight PT Cruiser News and Rumors 10 18 Jun 2009 08:57 am
2006 PT Street Cruiser Route 66 Edition skylight PT Cruiser News and Rumors 35 17 Nov 2007 02:39 pm
2007 PT Street Cruiser Announced skylight PT Cruiser News and Rumors 0 16 Aug 2006 08:47 am
2006 PT Cruiser Pics and New Specs skylight PT Cruiser News and Rumors 14 13 Nov 2005 08:46 pm
New 2005 Convertible PT Dream Cruiser skylight PT Cruiser News and Rumors 4 11 Jan 2005 06:12 pm
