Help on Installing LED Mirrors on My 06 Cruiser
  #61 (permalink)
Old 22 Sep 2008, 10:31 am
white's Avatar
Default Re: Help on Installing LED Mirrors on My 06 Cruiser
O Wow. Thought everyone had given up on signal mirrors for PTs. The ones I have are not bright enough to see during the day but work well at night. I am still looking for a better idea. I also think that the signals should be able to be seen from both the frunt and the rear to be really useful.
Signal mirrors are going to be everywhere by next year (but maybe not for PTs) although Chrysler does make a set that they put on the $$$$$ Vans.
E. White
2010 Black over Silver, Couture Edition
  #62 (permalink)
Old 22 Sep 2008, 10:45 am
I think the LED's that I ordered are supposed to be day-visible, and with the edge of the LED's hitting the outside edge of the mirror, it should be visible from the side and behind. There's also 24 LED's on each strip, and they are supposed to be higher brightness than the aftermarket mirrors I bought. I think it's an important safety feature, and should be on every vehicle. I want to make sure the guy in the next lane knows that I plan to change lanes.
From riding a motorcycle, I've learned that you have to make yourself visible to other drivers, as much as possible to prevent accidents, and stupid mistakes.
If these ones work out, I'll post up a tutorial on it so others can do the mod too.
2007 Touring Edition - Marine Blue Pearl
  #63 (permalink)
Old 03 Oct 2008, 05:50 am
white's Avatar
Did the 24 light LEDs ever arrive? If so what do you think?
E. White
  #64 (permalink)
Old 21 Nov 2008, 12:25 pm
white's Avatar
Hi Monkeyracer. Did the LEDs for your mirrors ever arrive and if so how did they work out?
E. White
  #65 (permalink)
Old 03 Jan 2009, 05:13 am
Signal Mirrors use high-intensity LED lamps to turn ordinary exterior rearview mirrors into safety features that command attention. When a turn signal is activated, a flashing chevron appears in the corresponding side mirror to alert drivers in the blind spot of your intentions.
smithsan
New Cars
  #66 (permalink)
Old 03 Jan 2009, 07:00 pm
nalati's Avatar
How did the Mirrors work out for you (are you Happy with them)?
About what did they cost and are they power mirrors?
  #67 (permalink)
Old 04 Jan 2009, 12:39 pm
white's Avatar
The thing is, yes you can get/use the chevron type units if you can find some that will fit the PTs mirror glass. You can also have a type that is built into the mirror housing or a type where the flashers sit on the outside of the housing. Look around, there are a lot of these different systems on cars now and some seem to be much better than others. My choice would be a small flasher that goes onto the bottom of our mirror housings that can be seen from both the frunt and the rear of the car. Some new Ford pickups have this type.
I did buy a set of new signal mirrors over a year ago. I mounted one of them and it works but not very good. The second one I used for parts and cut a nice hole in my PT mirror and installed the lights in it and it works but not very good. OK at night but not during the day time. There must be a better way to do this. The other thing you can do is what some VWs have, a small flasher mounted just forward of the frunt door (mounted on or into the finder)? That should work.
E. White
2004 Chrysler PT Dream Cruiser Series 3 skylight PT Cruiser News and Rumors 10 18 Jun 2009 08:57 am
2006 PT Street Cruiser Route 66 Edition skylight PT Cruiser News and Rumors 35 17 Nov 2007 02:39 pm
2007 PT Street Cruiser Announced skylight PT Cruiser News and Rumors 0 16 Aug 2006 08:47 am
2006 PT Cruiser Pics and New Specs skylight PT Cruiser News and Rumors 14 13 Nov 2005 08:46 pm
New 2005 Convertible PT Dream Cruiser skylight PT Cruiser News and Rumors 4 11 Jan 2005 06:12 pm
