the door spears are attached with double sided tape. they are easy to remove, id suggest a nylon pry tool to avoid scratching the paint. to remove the adhesive left from them after removal, 3M makes an adhesive remover that softens the tape enough to just roll it off.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs. Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways. |
Does anyone have a pic of a car without them. I think I saw a Cruiser that had none the other day in passing. WOnder if anyone makes a flat Stainless steel insert to replace them with. I am not sure I like the bulge look they give. thanks, bob
2001 Limited, Stone White, 5 Speed E&G everywhere, Vertical Grille, Running Boards, Sunshield, Continental Kit, Stainless Door sills, E&G Stainless bumpers, Chrome antenna bezel, Billet Antenna, Rocket Taillights, Borla SS Duals, 18" Proline Alloys I'm Lovin It |
Bob,
Yes, they do make a flat polished stainlees steel bar that replaces the door spear. (Old Pictures) ![]() ![]() You can find them here: PT Cruiser Side Molding - E&G: Race and Street
If you want to see a PT without spears, look at a 2008 Lx (base) or Touring, they come spearless now.
Street Cruiser package gets you the chrome spears. Maggie's the place to go for the flat SS Spears.
John & Terry ![]() "His" - 2002 Inferno Red Touring Edition "Hers" - 2003 Electric Blue Limited Edition Del Val PT Cruisers |
Where is Maggie's?
Can I just pull mine off and polish where they were? Thanks for the info.
Maggie's is www.RaceandStreet.com Click on the link I posted under my pictures above.
Yes, you can pull off the spears on your PT. There're held on with double sided tape. You'll have to get rid of the glue residue left over after you take the spears off and then bring the paint back to a shine.
I read somewhere that dental floss is good to remove mouldings that are held on with double sided tape. Should I heat the mouldings at all. Would like to preserve the spears for later use maybe. Are the flat SS spears very thick. Do they install easily? I think this wil be a good move for me.
Thanks
Dental floss or wooden flat picks that won't damage the paint. If you use heat (hair dryer) be careful of too much heat.
The SS flat spears are pretty thick, about 3/16th- 1/4 inch and go on the same way as the original spears, double sided tape.
Thanks Crewzin for all the help. Spring is on the way and I'm trying to get some stuff done. Runing boards and Lower grille housing should go to the paint shop next week. I just sent a note to Lee at E&G requesting a copy of the install manual for the Continental Kit. The stainless insert in the center needs removing and maybe replacing. Still havent figured out what to recover the running boards with. Someone mentioned using the Rhino coating like they use on Pickups Not sure yet. I really like the car and want make her really clean. Thanks for the help
Bob
| Dash Mounted Fog Light Switch | arkansascarnut | Exterior Accessories Forum | 10 | 29 Dec 2007 09:25 am |
| Hitch with roll pan | turbomangt | Exterior Accessories Forum | 11 | 03 Mar 2004 10:58 pm |
| Gear Shift Mounted Switches | Dalite | Turbo Performance | 6 | 16 Jun 2003 03:20 pm |
| Hitch mounted bike carrier? | PTCruuzinFL | General PT Cruiser Discussions | 1 | 30 Aug 2002 11:55 am |
