06 GT Turbo Rear LEDs
Old 29 Feb 2008, 11:48 pm
Default 06 GT Turbo Rear LEDs
About a year ago someone told me about an LED tail light kit for my 06 GT. Does anyone have any suggestions on a part number and a vendor for this?
Jay Guliano
www.ontimemall.com
Old 01 Mar 2008, 03:10 am
outfit's Avatar
Send a message via Yahoo to outfit Send a message via Skype™ to outfit
Lightbulb Re: 06 GT Turbo Rear LEDs
Try this site out...Street Glow Underglow Light | Neon Car Lights | Car LED Lights
Just nav your way through and you will find the LED bulbs and taillight kits...3157 LED Car Accessory Bulbs
These bulbs are great replacement for your existing brake and tail lights. No extra upgrades are needed, just install them, and you’ll see a unique look you never thought possible from your vehicle....Hope that helps
<---- Just installed.
2006 PT Cruiser Touring Non-Turbo
3 -Hyper White Thin Flexible 5mm LED Dome Lights from Oznium Damn they make a dif in the inside ,let me tell you the best led lights you can buy
1 -Hyper White 921 Superstar Bulbs from Autolumination
1 -Hyper White T10 Wedge 194 (Lic Pllate) Super White LED from Autolumination
Pioneer Head unit W/ HD & Satellite radio
2 - 7inch DVD/Headrests Monitors... dvd players built in the headrests
HID Lights 8000k 9006 for lows from xhidoutlet....
HID Slim 55w 6000K for high's from HIDGEEK.
Old 01 Mar 2008, 10:53 am
Exclamation Re: 06 GT Turbo Rear LEDs
Maggie at Race and Street has the LED Tail lights
http://www.raceandstreet.com
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 01 Mar 2008, 02:54 pm
Send a message via AIM to slayerdarkcross Send a message via MSN to slayerdarkcross
Default Re: 06 GT Turbo Rear LEDs
Are you looking for these?
I just installed them on my 07 PT Cruiser
I purchased them from here
2001-UP Chrysler PT Cruiser LED Tail Lights: U.S. SPEED
Old 02 Mar 2008, 01:53 am
Thanks,
I placed an on-line order today for a set of IPCW LED tail light kits. Looks like a 15 minute job to change out.
Jay Guliano
www.ontimemall.com
Old 02 Mar 2008, 02:01 am
Its an easy change but your going to have to play with the brackets to get it too be secure in the housing.
Old 03 Mar 2008, 08:20 am
I agree on the mounting clip issue. Be careful not to bend them excessively. The spring clips I've dealt with do have a finite life.
I think buying the entire assembly is a better option than just replacing the bulbs. We spent three days comparing LED 3157 "drop in replacement" bulbs and the stock 3157's. Finished the experiment by putting the stock 3157's back in.
It seemed to me that if the housing/reflector is designed for regular bulbs, it's very difficult to get an LED "drop in" to perform well in it.
Old 03 Mar 2008, 03:32 pm
outfit's Avatar
I agree...I did the same thing and found the same results. Even with clean lenses still didnt make a dif... Spend the bucks and get the entire thing..for anyone thinking about just getting the bulbs.....
Old 03 Mar 2008, 04:25 pm
Well, I'll have to sort of disagree because I think it all depends on which lights your talking about. I have the Caddy (Rocket) lights and replaced the regular bulbs with super white LED bulbs and it made a heck of a difference to the better. I bought the Super White for the amber lenses and the SR (Super Red) for the running/stop lenses. In a dark garage I put the LED's in on one side and regular bulbs on the other and there was a big difference when they (LED) were lit up. Click on "Auto Indulgence" to see the ones I used. You can also get them at Auto Zone.
Auto Indulgence
Old 03 Mar 2008, 05:10 pm
Crewzin - curious if the LEDs you used are the same as the ones in the link's picture. Also, do your lens assemblie have a smooth or "fresnelled" interior surface? I found not many sellers of the drop-in 3157's have any idea of the actual light output, or whether or not they will allow a stock tail/parking light assembly to meet FMVSS standards. Most dedicated LED lighting units have a housing designed specifically for LEDs and will not allow "backards compatiblity" with any other lamps.
The other snag was finding a suitable 5 pin flasher for the PT, to eliminate the burned out bulb rapid flash. You could modify the existing one, but if you're uncomfortable around SMD PC boards, that's pretty much out. The only other option is the load resistor fix.
I am glad to see your combination works, but can't believe that an end firing drop in with maybe 13 LEDs provides the same amount of visibility as an ordinary 3157. The ones we used were of the "tower" design, upwards of 27 LEDs, end and side firing, I presume in an attempt to used the reflector more effectively.
Turbo Replacement Question PTCruzzn General Turbo Discussions 7 06 Jul 2009 07:14 pm
Want to lower just the rear ove 03 PT GT Turbo Danny Brooks Turbo Wheels/Suspension/Handling 5 14 Jun 2004 11:02 pm
Suspension Techniques Sway Bars For the GT Turbo Gear_Head Turbo Wheels/Suspension/Handling 2 12 Sep 2003 02:51 am
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
