Hello,
I need to remove my fenders on my 2002 PT, does anyone have this in a book on how to...??? Would you please post on how this is performed. Thank you, The Rev. AC |
the easy way, start by jacking up the corner of the car you are working on and remove the inner fender liner (combination of hex screws and push retainers), lower car. raise hood. remove grille (hex screws, hooks on bottom). remove bumper cover ( 10mm bolts in corners, hex screws in wheelwells and along bottom and airdam, slides between headlamps and grille opening).remove headlamp (10mm nuts ). if passenger side, remove antenna and nut (may be frozen due to corrosion, penetrating oil may help but doesnt always). remove 10mm bolts from fender along top and bottom and inside jamb area, as well as the body side of the L brackets in the front. fender should come loose if all bolts have been removed. install is reverse. remember to transfer all hardware from old fender to the new one before install. good luck!
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs. Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways. |
There are couple bolts underneath. right by the door. there are 2 bolts then when you open the hood there are 3 or 4 bolts holding it down. then u have to go under the car and there is a couple bolts holding the front of the fender on. it should be right behind and underneath the light assembly. You might have to take the light out. make sure you don't pull it off to hard and don't bend it. one little bend and the whole fender and the fender flares will be not aligned and your car door will rub against it. Hope It works. Goodluck!!
lol - i searched all over the forums for this and didnt find it untill i googled < how to remove front corner panel pt cruiser > thank god for Google eh.?
| How to help needed: 02 PT Fender Removal | mtcaves | Tech & Performance Forum | 0 | 11 Mar 2008 11:35 pm |
| Cap in drivers side fender wheel? | DannyR | General Turbo Discussions | 14 | 17 Feb 2006 02:18 pm |
| pteazer fender flare | strangelove | Exterior & Interior Styling | 2 | 12 Jun 2005 05:29 am |
| Fender Removal | kevinl1058 | Exterior Accessories Forum | 6 | 23 Jan 2004 11:54 am |
| fender bender | onyx pt | General Turbo Discussions | 7 | 28 Sep 2003 10:21 pm |
