Originally Posted by PTmodrod
The 408 in the stang screams up to 7K faster than any car I have seen. It's a v8, a 408ci 6cyl would be a tad... silly. Pretty much 7 liters
opps my bad, yes a 408 in a 6 cyl would be a bit of a stretch
and most likely not even doable , stroke it an bore it to the max maybe?????----the stang is way easier to get the power to the wheels and to the track ,, IF you could get some really nice sticky slicks on the fount of the PT it would give him a run, but you are so limited on the size---I always wondered if it was quicker to pull a car thought the 1/4 or push it????
The stang should be able to pull the fount tires which looks cool but used precious 10ths of seconds,
On pinks they some times run the fount wheel cars, and man them make some power, and I have seen some 7.xx sec cars with FWD the burn outs look odd
