Hi, I have installed 6000K HID's in the low beams and 3000K in the fog lights. Both kits are 9006 and the majority of HID kits on the market come with the straight connector bulb. This is not a problem for the foglights either since there is enough room in front of the wheelwell cover. The low beam ballasts in mine are mounted right up beside the bulbs in the headlight assembly, and the foglight ballasts were mounted the same way. I had some friends at a performance shop install mine and both installs were done in less than an hour. They take off the front wheels which makes the job much easier, and the foglight install required them to unscrew the wheelwell cover (3 screws) in order to get the ballast into place. I bought both kits from EBay and the seller was "Intense HID". These kits are Japanese with a 1 year warranty and they have performed great. The difference is absolutely phenomenal. You don't have to pay huge prices for these kits to get quality so don't let anyone tell you different. Check out the 2 websites- www.intensehid.com or Welcome to Xenon-Vision :: L.E.D & HID Lighting System.
I know bring up a dead topid and all...
But I just spent the day looking at HID kits... I ended up going with the EFX euro effects 9006xs kit... Paid $149 for it shipped... They have a lifetime warrenty on the bulbs and ballasts now... Will take pics and let you guys know how they look when they arrive later this week... ) I'm stoked as I drive over an hour to work in the dark and don't want to meet any deer!
2005, Cool Vanilla, Slate Grey interior, Turbo Vert' Iridium plugs, K&N Typhoon intake.. Wrapped up in 16" Perelli rubber... Viper remote start alarm system, JVC AVX-820 (7" LCD, AM/FM/CD/DVD/Bluetooth), 10" rockford fosgate with a 300w amp... CLICKY, Jered's car domain page |
I got mine in the other day and hooked it up...Well wouldn't you know it... THE ALL DREADED FLICKER.... To my knowledge this kit and this seller it was not suppose to do it and was a plug in play... My ride is an 06 PT, did yall have to use the power relay kit???? If so where did you get them from??
2006 PT Cruiser Touring Non-Turbo 3 -Hyper White Thin Flexible 5mm LED Dome Lights from Oznium Damn they make a dif in the inside ,let me tell you the best led lights you can buy1 -Hyper White 921 Superstar Bulbs from Autolumination 1 -Hyper White T10 Wedge 194 (Lic Pllate) Super White LED from Autolumination Pioneer Head unit W/ HD & Satellite radio 2 - 7inch DVD/Headrests Monitors... dvd players built in the headrests HID Lights 8000k 9006 for lows from xhidoutlet.... HID Slim 55w 6000K for high's from HIDGEEK .
the only 2 solutions i have found so far are: get the "non flicker kit" which makes the 35w ballast, use 55w (making the car see 55w) or get 50-55w ballasts i am looking at what it takes to make a "non-flicker kit" i work with a few electrical engineers (me being mechanical i have no clue) and might be simple as a small rectifier...easily built with el-chepo parts. i will update you all tomorrow, when i find out. |
Hey Stone White...
I'm looking to convert my PT to HID lights this spring. I drive many miles every day on dark rural roads so this is a perfect mod for me. I looked up your source on 3B specialties but they are a pricy group. Probably high quality thought I suppose. So here are my questions about your HID experience: 1. I want to go with 8000k for my low beams & 6000k for the high beams - seems like the best light output/cool look combination to me. 2. Can you comment on the sources I have found for the kits below: I found this source for the 9006 type low beams on amazon:Amazon.com: XenTec HID conversion kit 9006 (HB4) 8000K Single Beam Xenon (Thunder Blue): Automotive Same source for the 9005 type high beams:Amazon.com: XenTec HID conversion kit 9005 6000K Single Beam Xenon (ultra white): Automotive 3. These kits seem like most mechanically inclined folks can do the install themselves - can you comment on that? It seems to me mounting the ballast and making sure the wires are routed well and tied down away from heat sources is the way to go. XenTec actually quotes their quality defective rate as "0.3% comparable to OEM HID lights" - that seems pretty good to me. Unless OEM HID lights have a tendency to burn out (but that would be news to me). For about $200 large I can have full HID conversion. Sounds good to me. Your thoughts? Thanks, Tom
Base '03, Light Almond Pearl Metallic - Modified 2.4 na w/ported head, 10.4:1 compression ratio & Crane #10 camshafts - 4 speed - Energy Poly bushings - Napa ceramic pads & Ultra premium rotors - Rotora Stainless brake lines - Extreme Acc. Xenon HID 8k low & 6k high Dark taupe & Ivory Interior, Factory CD w/Sirius Stratus 4, Power Acoustik 840w 4ch, Boss 200w 2ch w 10" bandpass sub, 2 sets Phoniex Gold Matched comp. speakers Rolling stock: 16" SE A7w 225/50/16 Kuhmo Ecsta AST - One of the nicest Light Almond PT's you'll find
Hi Muzicmax,
I have a 2006 PT and I have just installed HID 5000K headlights in place of the 9006 low beam Silver Star headlights that I had replaced the factory ones with two years ago. I had the HIDs installed and running in under two hours with the extra wiring harness I needed from Intense HID. Intense HID - HID LIGHTING SPECIALIST (So far, so good) I'm in Calgary as well so please e-me youor phone number and a good time to call you and I can give you the details of the install.
2006 PT Cruiser GEEK! |
| NeverBurnOut HID Kits | NeverBurnOutHID | Vendors & Buyers Forum | 2 | 05 Sep 2007 03:19 pm |
| F/S Rear Disk Brake Conversion | latinkng | Classifieds: For Sale/Trade | 1 | 19 Apr 2007 02:31 pm |
| Eibach sway bar installation kits | bluewasp | Wheels, Tires, Suspension | 13 | 15 Oct 2004 01:21 am |
| Mopar Gauages and Stage 1 kits in Canada | GLH_TC 16V | Vendors & Buyers Forum | 1 | 12 Sep 2003 12:57 pm |
| stage 1 kits are here | tthrift | Turbo Performance | 16 | 27 Jun 2003 09:33 pm |
