Grille Lighting
  #11 (permalink)
Old 20 May 2008, 08:25 am
DJmart's Avatar
Send a message via AIM to DJmart
Default Re: Grille Lighting
That would be kinda cool, but I have really no where to mount them..... i would have to take the grille out and change the resistor.
Seems like a bit of a hassle.
Ill consider it
  #12 (permalink)
Old 20 May 2008, 05:20 pm
PTmodrod's Avatar
Ill consider it
You can mount the LEDs to the back of the crush bar pointing down,thats where I mounted my LED tube. As for changing the resistor, there is another way, you could copy that circuit you already have from the switch on and just mount the new LEDs pointing into the lower grille.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
  #13 (permalink)
Old 20 May 2008, 05:24 pm
DJmart's Avatar
Either way I still have to change the resistor, because the LED's are going to dim, due to the new two LED's drawing current, thus not enough current because the resistor is holding it back....
but yeah, it would still be on the same circuit.
  #14 (permalink)
Old 21 May 2008, 07:14 am
PTmodrod's Avatar
Either I am misunderstanding where you have put the resistor or I didn't describe my circuit well enough. I will draw a diagram, as I am bad with words. It will be up later tonight when I draw it.
Pictures of my PT
  #15 (permalink)
Old 21 May 2008, 07:17 am
DJmart's Avatar
The resistor comes off the 12v feed from the switched circuit.....
The resisistor coming from the 12v feed would have to have less resisting ohms to power more LED's
LED series parallel array wizard
Yeeeh
  #16 (permalink)
Old 21 May 2008, 09:04 am
PTmodrod's Avatar
Yeeeh
You are still talking about a different thing than me. I am saying that you draw the power from BEFORE the resistor and use a new one of the same type. you will now have 2 power cables coming from the load end of the switch that each run into their own resistors then from the resistors into their own LEDs then to ground.
Pictures of my PT
  #17 (permalink)
Old 21 May 2008, 09:05 am
DJmart's Avatar
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOH
I get it
Should be a tough job though, there isnt any room to move around in front of the car.
  #18 (permalink)
Old 21 May 2008, 09:12 am
PTmodrod's Avatar
if you take the upper part of the grille off, there is room to move between the crush bar and the radiator. Worst case, you may have to just unbold the front bumper which isnt too hard of a job. Though I will admit, I have more room than most in my front bumper as I bought the Cal Cru Shark front end.
Pictures of my PT
  #19 (permalink)
Old 21 May 2008, 09:14 am
DJmart's Avatar
I will scope things out.
LED's are somewhat annoying as they are directional, yet i usually "buff" the top of the LED to give it more spread.
  #20 (permalink)
Old 21 May 2008, 09:15 am
PTmodrod's Avatar
you could always purchase an LED bar like I did. easier to mount.
Pictures of my PT
Need Pictures of Hot Rod Grille drdave Exterior Accessories Forum 6 24 Nov 2004 05:37 pm
Chrome Grille Warning CHROMEDCRUISER Exterior Accessories Forum 5 27 Apr 2004 01:23 pm
E&G Horizontal Billet Grille - SOLD Jeff V Classifieds: For Sale/Trade 5 08 Mar 2004 08:17 pm
custom grille.. maxman Exterior Accessories Forum 1 14 May 2003 06:16 pm
Stull Grille PTPaul Exterior Accessories Forum 6 21 Jan 2002 03:33 pm
