front wing badge
Old 04 Feb 2009, 12:17 pm
zombie's Avatar
Default front wing badge
I'd like to know if there is a way to remove my front winged badge emblem without ruining my paint job. Any ideas.
Old 04 Feb 2009, 12:26 pm
Default Re: front wing badge
Zombie,
All the badges are put on with 2 sided tape but if your talking about the actually wing on the front tip of the hood, there is also two pins that go threw the hood and have small metal tabs that have to be removed first. Open up your hood and your see the two holes and the pins that come from the wing. Pry the tabs off that are on the pins then your need some heat and fishing line or a small plastic/wood pry stick for the wing itself to come off. You'll still have two holes left on the hood when your done UNLESS they have changed things on the newer cruisers (mines a 2000) and they only used the 2 sided 3M tape to hold the wing on. If they did, you'll ave a clean hood when you take the wing off.
Old 04 Feb 2009, 01:30 pm
nope..2006- still has the holes.. had my badge removed and the holes welded up..was getting the bonnet (hood) painted anyway because of stonechips
Old 04 Feb 2009, 01:38 pm
Thanks for the update.
Old 05 Feb 2009, 12:46 pm
zombie's Avatar
Thanks for all the info.
Please help, front end shimmy survey Boomer Tech & Performance Forum 32 05 Oct 2009 01:54 pm
Front license plate placement spicy pt Exterior & Interior Styling 50 16 Oct 2008 08:52 pm
New Front Strut Question Gottasmilealot Wheels, Tires, Suspension 3 21 Apr 2008 12:17 pm
camber alignment kit needed for front ??? boosta Turbo Wheels/Suspension/Handling 7 10 Jun 2004 11:25 am
