Where is headlight relay fuse om 06 PT Touring
Old 08 Feb 2009, 02:02 am
outfit's Avatar
Send a message via Yahoo to outfit Send a message via Skype™ to outfit
Default Where is headlight relay fuse om 06 PT Touring
I need some help finding the headlight relay fuse...Anyone know where it is located ????
<---- Just installed.
2006 PT Cruiser Touring Non-Turbo
3 -Hyper White Thin Flexible 5mm LED Dome Lights from Oznium Damn they make a dif in the inside ,let me tell you the best led lights you can buy
1 -Hyper White 921 Superstar Bulbs from Autolumination
1 -Hyper White T10 Wedge 194 (Lic Pllate) Super White LED from Autolumination
Pioneer Head unit W/ HD & Satellite radio
2 - 7inch DVD/Headrests Monitors... dvd players built in the headrests
HID Lights 8000k 9006 for lows from xhidoutlet....
HID Slim 55w 6000K for high's from HIDGEEK.
Old 08 Feb 2009, 08:13 am
Default Re: Where is headlight relay fuse om 06 PT Touring
I'd like to help you out but in 06 Chrysler re-arranged the whole fuse panel thing. they did away with the inside-the-car set of fuses (which is where the headlight fuses used to be) and put everything on one circuit board under the hood I believe. Do you have an owners manual and doesn't it tell you anything about the fuses?
Old 08 Feb 2009, 12:02 pm
outfit's Avatar
I have one and in looking there are a couple of options...
Cavity 31 10 Amp Headlight Washer Relay Controll
Cavity 36 30 Amp Headlamp Washer Control
The reason I ask is because I bought an HID kit that was suppose to be a plug in play. it's the new slim ballast design w all the bells and whistles.. It does not have the relay that most kits come with that plugs into the battery, it does not need it, or thats what they say.. The thing that threw me is it says before Installation mode: If the vehicle is equipped with headlight relay, the fuses on both sides shall be changed into 20a as indicated in map.... Now I do not have any fuses on my end near the bulbs... .
Old 08 Feb 2009, 12:16 pm
I'm not sure about a relay, but on the 01-05 cruiser, there's a separate fuse for each headlight in the fuse panel next to the driver knee. You don't have that small separate fuse panel in yours so I would think somewhere in the fuse panel in the engine compartment are the fuses/relay that you need.
One of the members on this forum (Hooligan) sent me a picture of the fuse panel that the newer cruisers have (see below). I would think your owners manual should tell you exactly what all the fuses/relays are for.
Old 08 Feb 2009, 07:08 pm
outfit's Avatar
Okay , I thank you... That page was out of my book.... Going to look today ...
"no fuse" light came on!!! hermtm2 General PT Cruiser Discussions 13 04 Jan 2012 07:56 am
Ignition Off Draw (IOD) Fuse Effects and Replacement Hints ObiMatt87 Tech & Performance Forum 15 24 Apr 2011 03:41 pm
POWER WINDOW MOD WAYNEF Interior Accessories Forum 13 13 Jan 2005 05:40 pm
New reason to love my pt! technobear General PT Cruiser Discussions 9 03 Aug 2004 07:16 pm
Autometer gauges PTGT Redman Turbo Performance 12 23 Jul 2003 09:08 am
