anybody installed LED's in talllights
Old 12 Feb 2009, 01:02 am
Default anybody install LED's in talllights
so drove from Austin to Corpus Christi, Tx one night and got stopped four times for a burned out brake light.
SO before I go buy just the regular bulbs I thought about upgrading to LED's
SO what are your guy's experience with them?
I know most likely I'll need to get load balancers, I'm just curious about the light output.
Old 12 Feb 2009, 07:39 am
Default Re: anybody installed LED's in talllights
Auto zone has a whole stock of LED's that are exact replacement for normal auto bulbs. I don't think you need any kind of load balancers. I have the rocket tail lights and replaced the brake/running lights with the LED's and they work fine.
Old 12 Feb 2009, 08:17 am
I have direct replacement LEDs in the tail/stop light. Only if you replace the turn signal do you need balancers (or else your turn signals will be strobes).
The tail light is every bit as bright, but when I step on the btake, it's LOTS brighter.
Old 12 Feb 2009, 08:50 am
Forgot to add that I replaced the turn signal bulbs with Halogen for just that reason.
Old 20 Feb 2009, 05:56 pm
The only problem from LED replacement bulbs is some cars will get warning lights on in the dash that the bulb is out. Otherwise, they work good. Make sure you get the ones with the SMD leds in them.
LED Lighting blog
Old 01 Mar 2009, 03:13 am
interesting read u learn somthing new u might use in the future everyday....
SMD??
Old 01 Mar 2009, 11:52 am
brightlight07's Avatar
Send a message via Yahoo to brightlight07
i put the direct replacement led bulbs from autozone and yeah theyre bright but i took them right back out and put the og back in becuz they dont fill out the circle they are supposed to...and they dont seem to be as bright as the og
Psi-Fi PowerPaq installed. WOW!!! ksquared11 Turbo Performance 17 13 Jan 2008 04:26 pm
2004 Dodge SRT4 FS Chicagoland w/Chromoly roll bar installed! newbee101 Classifieds: For Sale/Trade 0 08 Nov 2007 02:15 pm
Pillar Pod and Gauges installed Mean Green Turbo Performance 25 12 Nov 2004 01:38 am
REQ: Images of Overhead Console Unit Installed neps Interior Accessories Forum 0 22 Jun 2004 06:42 pm
TurboXS RFL BOV and AGPTurbo BOP installed!! RobGT Turbo Performance 1 23 Jun 2003 05:38 pm
