hatch problems
Old 16 Jun 2009, 08:52 pm
superpug666's Avatar
Default hatch problems
hi guys... i need your opinions on why my hatch door "clunks" when i open it. I really have to almost force it, and sometime it barely makes any noises....i looked at everything i can and everything looks good.....HELP! lol
I drive an hybrid, it burns both gas and rubber!!!!!
To hell with all religions!
Yes my baby is stock, for now!
Old 17 Jun 2009, 07:48 am
Default Re: hatch problems
What year? Up until '05, the latch was mechanical, then it went electrical.
I'll assume yours is mechanical. I'd get some silicone spray and apply generously to all parts of the latch mechnism you can get at.
Old 17 Jun 2009, 04:45 pm
it is indeed, i have an 04GT...the latch works proprely because it unlocks wellthe first few inches are ok..its the rests.....thanks!
Old 17 Jun 2009, 07:59 pm
So it unlatches OK? Look carefully at the hydraulic struts. See if they're loose or defective.
Old 17 Jun 2009, 08:07 pm
they black part is starting to be rusty....and i aint sure about the way they "sit" where they bolt up....looks crouked to me, but i looked at a hatch on ebay and on the pic it looked off too......
Old 18 Jun 2009, 07:44 am
I hate to admit it, but when mine did this about a month ago it turned out that I had closed a freakin screwdriver in the seam on the right which jammed the liftgate to the bodypanel. Check to see if there's some kind of obstruction, or if the beauty panels have come loose and are sticking.
If there's nothing obstructing the motion then I'd replace the gas springs that provide the counter-force needed to lift the gate. Over time they age and the seal leaks slowly. Once the nitrogen in the cylinder is depleted they will no longer "spring" and can jam internally, which may be the cause of your sticking and clunking when you open it, loss of the pressure in the cylinders themselves will cause the liftgate to "feel" heavier and make it harder to open.
$27 ea (+tax) at AutoZone
Old 18 Jun 2009, 08:40 am
thanks man! but i wont go at autoszone, altho id love to....kinda hard up here because that store doesnt exist.....ill try canadian tire or UAP/NAPA!
Hatch latch malfunction Dragula General PT Cruiser Discussions 10 26 Mar 2011 03:37 pm
Pop the rear hatch open using the remote zapwizard Exterior Accessories Forum 4 28 Jun 2007 08:32 pm
Rear Hatch Opener Install ? StevenAndEva Sound and Security Forum 1 24 Feb 2006 12:23 pm
Handles for Rear Lift Hatch Dundevil Exterior Accessories Forum 6 05 Aug 2003 04:59 pm
Hatch no longer turns inside lights on Dalite General PT Cruiser Discussions 3 28 May 2003 12:17 pm
