Black Bumper Fix
Closed Thread
Old 20 Jun 2009, 08:21 pm
Default Black Bumper Fix
This fix for the black bumpers on the early model PT's is brought to you by Chris15.
First off, thank you! Now, onto your problem.. Yes, the 'tape marks' are quite unsightly, and both you and I missed the bandwagon to have Chrysler repaint them for us.
You should also be aware that if you're like me, you'll finish your front bumper and realize that your trim pieces (front splash guard and rear splash guards) don't match your bumper colors. You'll probably want to recoat them too. If you have a Haynes manual, it'll tell you how to remove them, but if not, let me know and I'll help you.
So, to do this, you'll need a couple things:
* Masking tape
* Newspaper
* Duplicolor Bumper Coating
* Duplicolor Adhesion Promoter
* Dish soap
* Bucket of water with sponge
The bumper coating I found at Autozone, but should also be carried at Advance Auto Parts of Pep Boys. I tried Walmart initially, but they don't carry it. They coating comes in either gray, black or white. I went with black. It will explicitly state on the front of the can 'Bumper Coating'. Don't buy anything else. It HAS to be this product.
Also at Autozone/Advance/Pep Boys, you should find a Duplicolor product called Adhesion Promoter. It's got a clear cap. Not primer or anything else, it HAS to be 'Adhesion Promoter'.
Here's how the job works:
1. Mix the dish soap in a bucket of water, clean your bumper (you will want to do each one separately) and allow it to air dry.
2. You will want to use the masking tape to tape off the edges of your body panels along the front bumper. After you've done the edges, go ahead and use the newspaper and another 'edge' of masking tape on top of the tape you've already applied to ensure that there's a good seal. How far you go with the newspaper and masking tape is up to you but beware of the effects of overspray.. and also keep in mind, as any painter will tell you.. the amount of time you spend in prep will determine the quality of your end result. Expect to spend a LOT of time masking things off. Ensure you mask off your reverse lights and also the light bulb that's located above your license plate.
3. Apply your Adhesion Promoter. You typically don't want to do this in temperatures exceeding 85 degrees F and high humidity. It will take 3 coats, with about 2-3 minutes between each coat.
4. After the last coat of Adhesion Promoter, allow it to dry for about 2-3 minutes and then apply you first coat of the Bumper Coating. You're now done with the Adhesion Promoter. You'll want to apply your first coat of Bumper Coating in somewhat of a 'mist'. Allow it to dry for about 5-10 minutes. Between coats you can also use a CLEAN microfiber cloth or cheese cloth to remove any bugs, dust, etc that gets stuck in your paint.
5. Apply your second coat, making sure you're applying the paint equally. Repeat this step again, but do not use more than 4 coats, as the paint will most likely run. If you choose to, you can also apply more paint to the 'tape marks' on your bumper, but be sure to fade the paint to get an 'even' appearance. (You don't want deep, triple black near your 'tape marks' and a lighter black/gray over the rest of the bumper-- discoloration is what you're trying to remove)
6. After you're done, allow the paint to fully cure for at least 5 days before you wash, wax or detail your car.
Then, enjoy!
Before and After Pic.
Closed Thread
pteazer smoothie full grille bumper jlogsdon Classifieds: For Sale/Trade 2 21 Apr 2008 12:25 pm
Easy Fix For Those Holes in Your Bumper!! Gracefulspice Exterior Accessories Forum 6 22 Oct 2007 02:34 pm
Black lower piece on front bumper? KingKole02 General PT Cruiser Discussions 11 25 Jul 2004 10:00 pm
Information on bumper repair, please!! javi21 General PT Cruiser Discussions 6 02 Feb 2004 10:50 pm
CHROME METAL BUMPER COVERS LITCH6 Exterior Accessories Forum 7 06 Dec 2002 09:34 pm
