Under lighting neons/LEDs
Old 14 Dec 2009, 11:56 pm
cmathew's Avatar
Smile Under lighting neons/LEDs
i just did the inside of my PT, im looking into doing the outside now =D
wondering what the arguments on neons VS LEDs are, i was thinking id go with Purple for the color, my PT is Patriot blue
main thing im worried about is price, actually looks, and ease of installation
Mostly stock, LED's lighting the floors up
Old 16 Dec 2009, 06:10 pm
Default Re: Under lighting neons/LEDs
They both install in about the same way except the LED's usually have 4 wires to hook up whereas the neon's can be hooked up in a series and you only deal with the one wire at the end. The LED's now-a-days usually have a small computer and you can have them come on in a thousand different patterns, different speeds, different colors. The LED's are, of course, more expensive.
Unless they have changed in the last couple of years, the neon's are more prone to break if hit by a rock or debris, but from what I've seen the neon's are a bit brighter than the LED's.
Old 17 Dec 2009, 06:15 pm
chris15's Avatar
Had a 7-color LED underbody kit from Optx (same as Streetglow) and liked it a lot, although I did have problems with the tubes only half lighting up. Then I lowered my car and broke both side tubes on the first speed bump I took. Go with the LEDs. Spend a little extra and you'll be much more satisfied. Theyre brighter, use FAR less power and look sweet to boot.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 23 Jan 2010, 05:46 pm
Definitely LED, i got the million color kit, and 7 color interior for just under 180$
as for ease of installation mine took me 6 hours of drilling, zip-tieing, and finding a way to get them to connect to the fuse box.
Neons under the dash USNNukeVTPT Interior Accessories Forum 12 24 Aug 2009 08:36 pm
in car leds YoungCruiserrr Interior Accessories Forum 11 02 Apr 2009 08:07 am
neons PT Chix General PT Cruiser Discussions 5 15 Sep 2004 08:26 pm
Neons in Grill Help Please Almond Lush Exterior Accessories Forum 5 26 Apr 2004 02:17 am
New Neons!! Airbillster Exterior Accessories Forum 0 27 Aug 2003 10:51 am
