High-output Headlight Harness
Old 24 Oct 2003, 02:26 pm
Default High-output Headlight Harness
Was curious if anyone had any experience with these headlamp harnesses that wire your lights directly to the battery, increasing the net voltage they receive. I had a harness similar to this one on my old vehicle, and I had great results from them - but the darn connections rusted out after 3 trips off-road! [xx(] I imagine I'd have to use some kind of grease or something at the connections to prevent it from happening again? [:I]
Any experience or advice for these things regarding the Cruisers?
Here's a link that shows a good picture of what I'm talking about.
http://jen.liu.tripod.com/suvlights/id14.html
Thanks in advance!! [?]
Old 24 Oct 2003, 02:46 pm
CarolinaBlueGT, You can use a little conductive grease in the connector. I have my horns connected through a relay like that. I used silicone sealer in applied from the outside into the back of the connector itself to seal out any moisture. I also sealed ANY exposed connectors (ground etc..) I used black sealer. With careful application this makes an excellent way to seal out moisture, It also doesn't require a large investment, except for your time........
Old 24 Oct 2003, 02:55 pm
Hey Alan, I was thinking about the silicone on the outside as well, but if you've ever seen these setups for the headlights (don't know what your horn one looks like), you'd need to be able to have access to the bulb/connector point in order to change the bulb. I'd imagine that if you siliconed it, it wouldn't make bulb replacement too easy of a task. But I hear you regarding the conductive grease and siliconing all the OTHER points. I guess the bulb connection would be the weak link in this chain. Is the conductive grease that silver stuff you use w/spark plugs? Dilectric grease or something like that?
I'm just concerned with all the hubbub I've read in these posts regarding brighter bulbs that the excess heat (although minimal with OEM wattage bulbs) might be a problem for the housing, or if I'd even be able to fit the harness in there in the first place (not knowing how cramped it is in there behind the bulbs)
Thanks!
Mike
Mike
2003 Patriot Blue GT
\"R\" Package
Autostick
K&N drop-in w/both airbox silencers removed
Brand \"X\" Turbo-up pipe
Old 25 Oct 2003, 12:18 am
A couple of the guys installed that exact harness. Need to put in some dielectric grease in the sockets (recommended even for OEM wattage bulbs). Chino replaced his burned sockets many times (even with HD sockets) and finally had to replace the OEM harness (from his posts, I don't believe he tried an aftermarket add-on harness). Excessive heat is a concern. Some have had the reflector discolor or have burn marks, some report discoloration or fogging on the inside of the outer plastic lens, while others say no problem. I suppose YMMV. I know some people removed the rubber o-ring from the bulb and drilled a slot at the bottom of the light bulb base to allow the heated air to escape (copying the H-1 thru H-4 bulb designs). But there isn't a rubber cover/water/vent shield like you find with a H-1 and H-4 setup.
On my Capri, I used to have add-on protective plastic covers over my lead crystal Cibie headlights (80-100w H-4, and 130w H-1), but they discolored from the heat after a year or two. I would be hesitant in using high wattage bulbs in the all plastic construction of today's aero style headlights. Personally, if they were available, I would go for better optics, like the european e-code lights, over higher wattage and/or fake HID look bulbs. OR buy direct replacement real HID headlights, not those illegal plug-in HID bulb conversion kits. Sylvania only offers 50 state approved HID replacement headlight assembilies with harness and relays for Ford and Chevy pickup trucks.
Old 25 Oct 2003, 12:33 pm
I considered that same harness for my PT, but after burning the reflective coating off my fogs with an increased wattage bulb, I didn't.
I think Hella designed a great headlamp and am quite satisfied with the overall beam pattern. The OEM Sylvanias burn brightly as-is. Besides, you don't want to start messing around with bulky electrical under that cramped hood, do you?
I contacted TYC - maker of projector-style headlamps - and inquired about the PT. No dice. Seems there are models for everybody else but us [V]
Free intake for 04 High output PT Turbo AEM engineer General Turbo Discussions 8 23 Jun 2004 03:20 am
Got my High Output emblem Mean Green General Turbo Discussions 17 30 Oct 2003 05:25 pm
High Output Emblem Mr.Blonde General Turbo Discussions 3 03 Oct 2003 12:40 am
High Output Emblems tthrift Vendors & Buyers Forum 0 30 Sep 2003 10:30 am
High Output Emblem tthrift Vendors & Buyers Forum 5 12 Sep 2003 11:12 am
