lights in lower front cowl
Old 13 Dec 2003, 06:32 pm
gonzomania's Avatar
Send a message via AIM to gonzomania
Default lights in lower front cowl
Can parking, running or fog lights be installed in spaces under front bumper and is the wiring harness already there?
Old 13 Dec 2003, 07:10 pm
Gonzomania,
Running/fog lights are already installed on the Limited Edition cruisers in the outermost holes under the bumper. Not sure about the Base, or Touring models. I don't think the wiring is there if the lights didn't come with your model, but I would think it wouldn't be too hard to set up your own lights and place an on/off switch on the dash.
Old 13 Dec 2003, 10:02 pm
The wiring is already under the bumper even in the base model. You would need to buy the relay and column switch from DC or find out what wires you need to tap into behind the dash for an aftermarket switch.
Steve
Old 14 Dec 2003, 12:35 am
Yep CREWZIN, the touring edition does come with the running/fog lights as standard equipment.
Neil from Maine
2003 Patriot Blue PT Touring Edition
Old 14 Dec 2003, 01:11 pm
Did in '02 model anyway. with how they cut back (no heated mirrors, mirrors no longer fold, etc) don't know 'bout '03 or '04. I would think FINDING the right wires in the harness could be a chore.
In any case, go to PTDoItYourself.Net & look at Aoogah horn instructions - the wiring would be the same, and you might want the same console switch location.
Old 15 Dec 2003, 02:54 am
2sb 2sb is offline
Are you wanting stock or aftermarket lamps?
Old 15 Dec 2003, 03:25 pm
Go here for more info: http://www.ptcruiserlinks.com/forum/...rchTerms=pilot
Old 16 Dec 2003, 10:06 pm
my wife has an 02 base and the wiring is there for the fog lights
Old 16 Dec 2003, 11:47 pm
Stephen R., those look nice! [^]
2002 Inferno Red PT Limited
Mercedes Wiki
Black lower piece on front bumper? KingKole02 General PT Cruiser Discussions 11 25 Jul 2004 10:00 pm
Easy way to make front end look lower clevelandmike Exterior Accessories Forum 5 04 May 2004 08:13 am
lower cowl to bumper gonzomania General PT Cruiser Discussions 12 18 Apr 2004 09:07 pm
front lower tie bar OurPTGT Wheels, Tires, Suspension 7 23 Oct 2003 04:41 pm
Front Lower Arm Bushes piperglover Tech & Performance Forum 1 10 Dec 2002 06:03 pm
