Fog Lights
Old 24 May 2011, 11:25 pm
Default Fog Lights
I have a 2003 base model and I was looking and there is a spot to hook in fog lights but there is no switch on the dash or counsel? Is there a way that I can run fog lights when it never came with them?
Old 25 May 2011, 12:25 am
Default Re: Fog Lights
Yes. If your car has the connectors in place behind the bumper cover, you can easily install fog lights. You will need to wire in a switch. The easiest plug-&- play method is to replace the steering column multifunction switch with one that has the fog light feature. These switches have had chronic malfunctions so you can choose instead to install a separate switch, but this means you need to do some DIY wiring.
Here is a link to my fog light addition on a 2004 base nmodel.
Replace Multifunction Switch w/fog lamps
I also installed a relay to protect against leaving the fog lights on when the ignition is turned off.
my door locks,head lights and tail lights don't work. bones02 Tech & Performance Forum 38 06 Apr 2016 10:30 am
Head Lights and Tail lights not working. 1morgana General PT Cruiser Discussions 6 15 Nov 2014 12:38 am
HELP! '02 Cruiser with no tail lights, then no brake lights. tschauer Tech & Performance Forum 1 16 Sep 2010 05:54 am
Smoked tail lights and reverse lights! chris15 Exterior Accessories Forum 15 01 Jun 2010 05:53 pm
Need a poll answered: Should I tint all my lights or buy euro/projector lights? 85_305 Exterior Accessories Forum 2 17 Jun 2009 08:38 pm
