Chrome/SS Pillars
Old 01 Jul 2011, 07:15 pm
AyeCantSeeYou's Avatar
Default Chrome/SS Pillars
Has anyone ordered any of the chrome/ss pillars and been happy with them? Were they easy to install and an accurate fit?
I probably should have asked this BEFORE I just ordered some. LOL
I just couldn't take looking at the discolored black ones on my PT any more. I had been searching for some to replace the ones on my car now for several days.
2002 PT LE, loaded - stock
Old 01 Jul 2011, 07:40 pm
WolfmanG's Avatar
Default Re: Chrome/SS Pillars
to my knowledge i would think they fit good right on top of the stock ones. Honestly i wouldn't know, i use metallic vinyl on my pillars.
-Danny Wolfman G
Old 02 Jan 2012, 01:50 am
I hadn’t ordered chrome/ ss pillar neither I had replaced it with newer ones, this is the reason why I haven’t have any knowledge about it. I have observed many of my friends frequently discussing about the obstacle they had faced while replacing chrome ss pillar while they are beginners.You can replace it with newer one only if you have small knowledge about it otherwise it is not advisable for you to go for replacement on your own.
goldwing parts
Old 02 Jan 2012, 06:31 am
I've had several friends order them from Maggie at Race & Street and they all fit fine and not a single complaint. I would prefer her's in SS over the Autotechnica chrome one's. SS will last a lifetime. There are some out there that are SS and have a PT logo on them for the rear windows, but I'm not sure where.
Old 02 Jan 2012, 12:03 pm
harrym's Avatar
I got mine from Maggie - the Autotechnica Stainless Steel ones that Chromenut refers to - and I have no complaints. If you follow Chromenut's advice (to summarize: clean pillars thoroughly, then clean again. Make sure temperature is above 56 degrees Farenheit. Apply carefully, making sure you get them straight. Did I say clean area thoroughly?) I have had to reinstall a couple of mine this winter - the stainless steel pillars are flatter - not curved exactly like the stock door pillars - and they tend to pop loose either at the top or bottom. Solution is to get some of the red 3m tape - remove the pillar and clean, then reinstall. Not a problem, I probably didn't get the area cleaned well enough to start with!
Old 02 Jan 2012, 12:16 pm
You can also take a heat gun or hair dryer and heat them up pretty well, before installing, and just give them a subtle bend. Friend of mine did his at my house at a tool time and we just gave them an ever so slight curve over the handrail on my deck. Worked perfectly and no issues with them popping off.
Chrome window pillars Kalel8 Exterior Accessories Forum 4 12 Jul 2008 03:26 pm
b, c and d pillars 4SPEED Exterior & Interior Styling 7 28 Dec 2006 04:20 pm
A-pillars gonzomania Interior Accessories Forum 1 31 May 2004 10:45 am
Show me your pillars turbomangt General Turbo Discussions 11 09 Apr 2004 02:45 pm
"B" Pillars GTPT Exterior & Interior Styling 8 13 Jul 2003 05:14 pm
