please help with Daytime running light led stripes wiring
Old 25 Jul 2011, 04:50 pm
Dimitry's Avatar
Send a message via Skype™ to Dimitry
Default please help with Daytime running light led stripes wiring
have a problem wiring up a led stripes to a oem drl/turn signal so basically oem connector has one coloured and two black wires one black wire in the middle has yellow stripe, i thought it should be simple one common ground and one positive to a blinker and one positive to a daytime running lights.
wright now the orange bulb is running as DRL when you drive and starts blinking if you're turning the signal on, what i want to do is use LED as a DRL and orange bulb only for turn signal as its gonna look like a Christmas tree white led stripes together with orange bulb as DRL. is there any way to separate DRL from turn signal ? help would really appreciated as pt is without headlight now.
03 PT black 2.4 turbo manual. mine
02 PT silver 2.4 n/a manual. wify's
01 PT inferno red limited edition 2.4 n/a auto. mom's
Old 25 Jul 2011, 05:45 pm
Default Re: please help with Daytime running light led stripes wiring
Would like to help and I'm sure there's others that would too but the DRL's aren't on the cars in the U.S.
Maybe someone good with electrics and figure out what's wrong by reading your explanation and without having the schematic to go by. Our Haynes and Chilton manuals don't mention them.
The 01-04 On-Line Repair Manual has a paragraph on them:
But no diagram to go with it.
Old 26 Jul 2011, 07:55 pm
Dimitry's Avatar
ok i found another solution is there a wire to cut to disable DRL and then hook up the LED to that cutted wire so turn signal bulb will not receive the DRL contact instead it will go to LED stripes ? anyone knows how to disable DRL ? on 2001 and up models? thank
Old 26 Jul 2011, 09:08 pm
Dimitry's Avatar
ok here it is the problem solution :
from diagram seen that DRL module is in the instrument cluster and comes like a one unit and from IC coming the same two positives wires TAN/RED for one side and LIGHTGREEN/ORANGE for another side, these wires can be found by the turnsignal bulb plug under the hood it means there is actually no way to disable DRL without rewiring the turnsignal as crewzin stated signal from blinker relay goes to I/C so basically you haave to wire turnsignal directly from blinker relay pass the I/C which has DRL internally.
Old 26 Jul 2011, 09:17 pm
Alright, your answered your own question. Glad you got it sorted out.
Old 26 Jul 2011, 09:25 pm
Dimitry's Avatar
i wish it wasn't true now i can't connect my led stripes the way i wanted
daytime running lights module frances General PT Cruiser Discussions 17 10 Feb 2017 11:51 pm
:question:daytime running lights!!!:question: jrs61282 Tech & Performance Forum 10 07 Nov 2010 10:53 pm
Fog Light Wiring h100250 Tech & Performance Forum 10 02 Nov 2009 06:03 pm
Daytime Running Lights SteveANJ General PT Cruiser Discussions 6 05 Mar 2008 09:38 am
Daytime Running Lights Jay M Exterior Accessories Forum 0 14 Sep 2001 08:18 pm
