PT Cruiser Forum Car Videos
Car Rims
Fender Removal
Old 22 Jan 2004, 02:21 am
kevinl1058 kevinl1058 is offline
Default Fender Removal
Has anyone removed there front fender.. I have a small door ding crease that I want out and the best way to take it out is to remove the fender so I can work it out with a body hammer..Is it pretty easy to remove the fender?
Old 22 Jan 2004, 02:29 am
IRPT IRPT is offline
From the service manual:
FRONT FENDER
REMOVAL
(1) Remove headlamp housing.
(2) Right side of vehicle remove front side rail
access pulley splash shield.
(3) Remove splash shield.
(4) Remove fender to fascia nuts.
(5) Remove fender bolt to lower rocker panel (Fig.3).
(6) Remove fender bolt to lower cowl.
(7) Pull fascia away from fender.
(8) Remove bolts attaching fender to upper rail.
(9) Remove fender from vehicle.
INSTALLATION
(1) Place fender in position on vehicle (Fig. 3) .
(2) Start the center upper rail bolt.
(3) From inside engine compartment, install all
the bolts attaching fender to upper rail and tighten.
(4) Install lower cowl panel bolt to fender.
(5) Install rocker panel bolt to fender.
(6) Place fascia into position.
(7) Install fender to fascia nuts.
(8) Install inner splash shield.
(9) Install right side pulley splash shield.
(10) Install headlamp assembly.
(11) Check fender for flush and gap.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 23 Jan 2004, 12:17 am
Hooligan Hooligan is offline
Way to go IRPT, if a question is asked, you usually are one of the first to post the answer.
Old 23 Jan 2004, 12:38 am
Thanks Hooligan, I like to help, if I can.
Mercedes Wiki
Old 23 Jan 2004, 11:40 am
bobs turbo pt bobs turbo pt is offline
"I like to help, if I can" hey irpt can you get rid of this cold weather for me?? (lol( (just kidding) i feel the same as hooligan always there with great info!!
Old 23 Jan 2004, 11:52 am
Sure Bob, I can do that. That's a big job and will take me awhile but I'll start on it today. Expect to see the temps rising in about 3 months, 2 1/2 months if I continue to work on it on the weekends.
Mercedes Wiki
Old 23 Jan 2004, 11:54 am
[] roflmao
vB code is On
Cap in drivers side fender wheel? DannyR General Turbo Discussions 14 17 Feb 2006 02:18 pm
pteazer fender flare strangelove Exterior Accessories Forum 3 13 Jun 2005 09:24 am
pteazer fender flare strangelove Exterior & Interior Styling 2 12 Jun 2005 05:29 am
fender trim brackets scribs-turbo Exterior Accessories Forum 0 13 Oct 2003 03:17 pm
fender bender onyx pt General Turbo Discussions 7 28 Sep 2003 10:21 pm
  Car Insurance | Credit Cards | Locate Vets | Online Loans | Bad Credit Loan
