tool needed for replacement of rear struts
Old 16 Jan 2012, 01:57 pm
harrym's Avatar
Default tool needed for replacement of rear struts
What size star shaped screwdriver do I need to replace my rear hatch struts? I ordered a set from Maggie today.
Old 16 Jan 2012, 03:03 pm
Default Re: tool needed for replacement of rear struts
T-30 goes in but moves around a little bit, T-40 goes in tight. Take your pick. Do yourself a favor and buy a whole set of ratchet Torx sockets.
Old 16 Jan 2012, 04:50 pm
harrym's Avatar
Good idea. come to think of it, I might have a set in my tool box, if it has survived two moves - haven't used them since KC, and that was twenty years ago.
Replaced the IAC Idle air control valve? Special tool needed? worcestersauced Tech & Performance Forum 14 04 Apr 2016 01:22 pm
Whats needed for a timing belt replacement deryk Tech & Performance Forum 4 29 May 2011 09:19 pm
Oil Pressure Sensor ,What tool is needed outfit Tech & Performance Forum 2 17 Feb 2011 07:01 am
Replacement Struts and Shocks sscanlan Wheels, Tires, Suspension 1 13 Feb 2011 03:58 pm
Help with bell crank replacement needed stratman Wheels, Tires, Suspension 3 22 Sep 2009 11:14 pm
