Tail light interchangeability?
Old 02 Feb 2012, 10:31 am
Skyforger's Avatar
Default Tail light interchangeability?
Was wondering if the shape, and mounting points are the same for the newer +07 PTs with the red/white tails. Have a friend with an 07 who wanted to trade.
-Chris-
2003 Pontiac Grand Am GT Sedan - 152K
2003 Chrysler PT Cruiser Limited - 41K
2003 Mitsubishi Galant ES - 79K
2008 Cadillac DTS - 43K
Old 02 Feb 2012, 05:28 pm
Skyforger's Avatar
Default Re: Tail light interchangeability?
Nobody at all has done this? I'm surprised...
-Chris-
Old 02 Feb 2012, 07:03 pm
I've had 6 different tail lights from OEM in 2001 to the red/white of the newer PT's and a few in between. They all fit (sort of) but sometimes you have to mess around with the wiring of the bulbs. Nothing hard.
When I say "sort of", after market taillight seem to leave a small gap around the edge. If your going from the red/amber to the red/white then they will fit without a problem.
Old 02 Feb 2012, 07:22 pm
Skyforger's Avatar
Awesome! I just wanted to make sure, that's all.
Just need to get the new heads, 6000K HIDs, 3000K yellow fogs, debadge and it'll be set for the spring!
-Chris-
Old 03 Feb 2012, 11:39 pm
PiperGeorge's Avatar
The light bulb sockets are different between the old and new
Old 04 Feb 2012, 12:20 am
Skyforger's Avatar
What socket type does the newer one use then?
-Chris-
Old 04 Feb 2012, 05:03 am
Maybe I shouldn't say "light bulb sockets", maybe the light bulb holder is better? One of them mounts to the light housing with 3 tabs, and the others have 2 tabs. But if you are just trading with your friend it won't really matter because you just take the sockets with the lights.
One thing I found when I put different lights on my 2010 was that you had to play with the metal mounting springs on the lights. I had to spread them out a bit to keep the light tight against the body
Old 05 Feb 2012, 01:51 pm
Skyforger's Avatar
I'll keep that in mind. But that's why I have a dremel handy. lol
-Chris-
Old 05 Feb 2012, 02:01 pm
In changing to any of the different tail lights all I had to do is bend the metal springs a little closer towards the edge so they would hold better/tighter. That's probably with PiperGeorge was referring to. No drilling or dremel required.
Old 05 Feb 2012, 02:05 pm
Skyforger's Avatar
Oooooh. I see. I'm so used to interchanging parts with the Galant. JDM parts are always just a hair too big, or extra plastic in the way. lol
-Chris-
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
tail light broken, but brake light works dirtydmix General PT Cruiser Discussions 8 09 Mar 2011 09:59 pm
LH Tail light Travis2k7 General PT Cruiser Discussions 4 19 Nov 2010 10:03 pm
cant get my tail light off '01! yteka99 General PT Cruiser Discussions 18 12 Sep 2010 02:26 pm
Rim interchangeability ? zombie Wheels, Tires, Suspension 2 13 Apr 2009 03:50 pm
